Eclipse package won't run in Kubuntu 6.10 AMD64 [message #309575] |
Wed, 01 November 2006 03:03  |
Originally posted by: Xzyx987X.hotmail.com
I installed eclipse from the Ubuntu repository, but I can't seem to get it
to run. The following is the error log produced, which I haven't been able
to figure out myself:
!SESSION 2006-11-01 01:29:12.195
eclipse.buildId=M20060921-0945
java.version=1.5.0_08
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86_64
!ENTRY org.eclipse.update.configurator 2006-11-01 01:29:14.083
!MESSAGE Plugin does not have a valid identifier:
plugins/org.eclipse.cdt.source_3.0.1/
!ENTRY org.eclipse.update.configurator 2006-11-01 01:29:14.084
!MESSAGE Plugin does not have a valid version:
!ENTRY org.eclipse.update.configurator 2006-11-01 01:29:15.884
!MESSAGE Could not install bundle plugins/org.eclipse.cdt.source_3.0.1/
Error converting plugin at
/usr/lib/eclipse/plugins/org.eclipse.cdt.source_3.0.1.
!ENTRY org.eclipse.osgi 2 1 2006-11-01 01:29:18.956
!MESSAGE NLS missing message: initializer_error in:
org.eclipse.core.internal.runtime.messages
!MESSAGE NLS missing message: fileInitializer_fileNotFound in:
!MESSAGE NLS missing message: fileInitializer_IOError in:
!MESSAGE NLS missing message: fileInitializer_missingFileName in:
!ENTRY org.eclipse.osgi 4 0 2006-11-01 01:29:19.194
!MESSAGE Application error
!STACK 1
java.lang.UnsatisfiedLinkError: memmove
at org.eclipse.swt.internal.gtk.OS.memmove(Native Method)
at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 67)
at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 54)
at org.eclipse.swt.widgets.Display.<clinit>(Display.java:126)
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.ja va:433)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:161)
at
org.eclipse.ui.internal.ide.IDEApplication.createDisplay(IDE Application.java:122)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:75)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY org.eclipse.osgi 2 0 2006-11-01 01:29:19.205
!MESSAGE One or more bundles are not resolved because the following root
constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2006-11-01 01:29:19.205
!MESSAGE Bundle
update@plugins/org.eclipse.cdt.source.linux.gtk.x86_64_3.0.1/ was not
resolved.
!SUBENTRY 2 org.eclipse.cdt.source.linux.gtk.x86_64 2 0 2006-11-01
01:29:19.205
!MESSAGE Missing host org.eclipse.cdt.source_3.0.1.
!ENTRY org.eclipse.osgi 2 0 2006-11-01 01:29:19.206
!MESSAGE The following is a complete list of bundles which are not
resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2006-11-01 01:29:19.206
!MESSAGE Bundle
update@plugins/org.eclipse.cdt.source.linux.gtk.x86_64_3.0.1/ [112] was
not resolved.
01:29:19.206
!SESSION 2006-11-01 01:30:12.321
!ENTRY org.eclipse.osgi 2 1 2006-11-01 01:30:14.153
!ENTRY org.eclipse.osgi 4 0 2006-11-01 01:30:14.475
!STACK 1
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.osgi 2 0 2006-11-01 01:30:14.657
!SUBENTRY 1 org.eclipse.osgi 2 0 2006-11-01 01:30:14.657
!MESSAGE Bundle
resolved.
01:30:14.657
!ENTRY org.eclipse.osgi 2 0 2006-11-01 01:30:14.658
!SUBENTRY 1 org.eclipse.osgi 2 0 2006-11-01 01:30:14.658
!MESSAGE Bundle
not resolved.
01:30:14.658
!SESSION 2006-11-01 01:30:33.716
!ENTRY org.eclipse.osgi 2 1 2006-11-01 01:30:35.566
!ENTRY org.eclipse.osgi 2 1 2006-11-01 01:30:35.567
!ENTRY org.eclipse.osgi 4 0 2006-11-01 01:30:35.892
!STACK 1
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.osgi 2 0 2006-11-01 01:30:36.067
!SUBENTRY 1 org.eclipse.osgi 2 0 2006-11-01 01:30:36.067
!MESSAGE Bundle
resolved.
01:30:36.067
!ENTRY org.eclipse.osgi 2 0 2006-11-01 01:30:36.068
!SUBENTRY 1 org.eclipse.osgi 2 0 2006-11-01 01:30:36.068
!MESSAGE Bundle
not resolved.
01:30:36.068
!SESSION 2006-11-01 01:31:15.821
!ENTRY org.eclipse.osgi 2 1 2006-11-01 01:31:18.144
!ENTRY org.eclipse.osgi 2 1 2006-11-01 01:31:18.145
!ENTRY org.eclipse.osgi 4 0 2006-11-01 01:31:18.467
!STACK 1
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.osgi 2 0 2006-11-01 01:31:18.641
!SUBENTRY 1 org.eclipse.osgi 2 0 2006-11-01 01:31:18.641
!MESSAGE Bundle
resolved.
01:31:18.641
!ENTRY org.eclipse.osgi 2 0 2006-11-01 01:31:18.642
!SUBENTRY 1 org.eclipse.osgi 2 0 2006-11-01 01:31:18.642
!MESSAGE Bundle
not resolved.
01:31:18.642
Re: Eclipse package won't run in Kubuntu 6.10 AMD64 [message #309611 is a reply to message #309575] |
Thu, 02 November 2006 09:19   |
You're the second user that I've seen report this. Does eclipse work for
you if you download it from eclipse.org? If so then this is likely a Ubuntu
packaging issue.
Grant
"Xzyx987X" <Xzyx987X@hotmail.com> wrote in message
news:d5bdf272abc7a6d6e50098c591f5bfd8$1@www.eclipse.org...
> !STACK 1
> at
:122)
> at
java:78)
> at
> at
pLauncher.java:68)
> at
> at
> at
> at
..java:25)
> !MESSAGE Bundle
> resolved.
> 01:29:19.205
> !MESSAGE Bundle
> not resolved.
> 01:29:19.206
> !STACK 1
> at
:122)
> at
java:78)
> at
> at
pLauncher.java:68)
> at
> at
> at
> at
..java:25)
> !MESSAGE Bundle
> resolved.
> 01:30:14.657
> !MESSAGE Bundle
> not resolved.
> 01:30:14.658
> !STACK 1
> at
:122)
> at
java:78)
> at
> at
pLauncher.java:68)
> at
> at
> at
> at
..java:25)
> !MESSAGE Bundle
> resolved.
> 01:30:36.067
> !MESSAGE Bundle
> not resolved.
> 01:30:36.068
> !STACK 1
> at
:122)
> at
java:78)
> at
> at
pLauncher.java:68)
> at
> at
> at
> at
..java:25)
> !MESSAGE Bundle
> resolved.
> 01:31:18.641
> !MESSAGE Bundle
> not resolved.
> 01:31:18.642
Re: Eclipse package won't run in Kubuntu 6.10 AMD64 [message #311878 is a reply to message #309575] |
Wed, 24 January 2007 14:58  |
Originally posted by: fischer.sacred.net
I has this same problem; I tried Grant's suggestion which worked,
as long as the package was owned by me! As soon as I installed
it as root, I got the same error. So it doesn't look like an
ubuntu packaging issue.
I'm running ubuntu Edgy, and I installed the relevant ia32 packages,
which did not seem to help; nor did using the linux32 wrapper.
I'm using the most recent Sun 1.5 package, installed via synaptic.
Linux satyagraha 2.6.17-10-generic #2 SMP Tue Dec 5 21:16:35 UTC 2006 x86_64 GNU/Linux
Hope this helps.
FUDForum. Page generated in 0.03990 seconds
