Home » Eclipse Projects » Eclipse Platform » Linking to other help topics in other plugins
Linking to other help topics in other plugins [message #308366] Wed, 20 September 2006 12:10 Go to next message
In the eclipse help system, it is pretty straightforward to link to help
topics within the same plugin, but if, for example, I wanted to direct
the user to the Eclipse Workbench User Guide, how exactly would I do it?
Thanks for the pointers,
Keith
Re: Linking to other help topics in other plugins [message #308398 is a reply to message #308366] Thu, 21 September 2006 12:20 Go to previous messageGo to next message
I don't know if there is a nice was to do this.
Notice for example here:
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. pde.doc.user/reference/pde_feature_generating_build.htm
There is a link on the javacWarnings property that goes to the JDT
guide. This was done simply by using
"../../org.eclipse.jdt.doc.isv/guide/jdt_api_compile.htm" as the target
of the link.
This assumes that the jdt.doc.isv will be there, and is a little brittle
I think.
-Andrew
> Keith
Re: Linking to other help topics in other plugins [message #311642 is a reply to message #308398] Thu, 18 January 2007 11:56 Go to previous message
I dunno if it is less brittle, but in 3.2 there is an approved method, the use of a leading
"PLUGINS_ROOT" in the "url" of the link, as described here:
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/ua_help_content_files.htm
I've used it and it works fine; the Eclipse Help system gives a reasonable response when the link
points to a plug-in not included in the launch/export.
HTH,
Paul
Previous Topic:Programmatic closure of Wizard
Next Topic:Adding new services to editor sites or the workbench window so they are found via getService() (serv
Current Time: Sat Jul 19 05:26:38 EDT 2025
Powered by FUDForum. Page generated in 0.05417 seconds
