Synchronize with external files [message #300801] |
Fri, 17 March 2006 04:21  |
is it possible, to arrange a compare with external files, f.e.
- Project in workspace (not under source control, or other sourcecontrol as cvs) synchronize with moduls under source control (cvs)
or
- Project in workspace (not under source control, or other sourcecontrol as cvs) synchronize with files outside of workspace
with the same functions as the "Team Synchronize - View" (Override and Update ...) ?
Maybe an extension of the Team Synchronize View / Available synchronization types with something like other Files and File Chooser ...
Is there already an exisiting plugin with those features ?
Thanks for any hints !
Best Regards,
Christian
Re: Synchronize with external files [message #301464 is a reply to message #301358] |
Fri, 31 March 2006 04:41  |
Originally posted by: automatic.javalobby.org
Hi, Alex
>You could import the contents as a project if you wanted.
>Eclipse will create a .project file for a simple project at the root of the project itself.
>It doesn't need to be under the workspace though.
OK, i could create a project with links to the filesystem
>If you're using CVS, and each of the folders under the project has a CVS directory, then you'll be able to
>see the contents on a remote CVS server trivially.
Sorry, i don't get it.
Sure, if i have to projects in workspace, i'm able to do a ' compare with each other ' , then
i get a Structure Compare - but i need a synchronize view.
what i really want to do is a compare of two projects, with all the features i have
in the synchronize view.
Normally i do a ' Compare with Branch or Version ' between a project in workspace
under cvs control, with another Version/Branch of that project in cvs.
I need a synchronize feature, where i normally only have a structure compare, f.e. =
Synchronize of a project in workspace under ClearCase control, with a
Branch/Version of that project in cvs.
Synchronize of a project in workspace under ClearCase control with
another project in workspace (after import) or a project in filesystem
outside workspace.
Christian
FUDForum. Page generated in 0.04218 seconds
