Home » Archived » DSDP - Mobile Tools for Java (MTJ) » MTJ 0.9.1 on Linux vs. Nokia Phones
MTJ 0.9.1 on Linux vs. Nokia Phones [message #30057] Sun, 24 May 2009 08:47 Go to next message
Originally posted by: elwood.agouros.de
I am using Eclipse 3.4.2 on Linux with MTJ 0.9.1. This is mostly working
fine, however I have two questions:
1.) Is it possible to import the Nokia Stuff from a Windows install so I
can use it developing under Linux?
2.) The Midlet I am writing is working fine on a Nokia E60 and E50.
However it refuses to install on my N90. I am using WTK 2.2 and set the
thing to CLDC-1.1 MIDP-2.0 so this should work or am I missing something?
Konstantin
P.S.: Offtopic, but maybe someone has experienced this: The emulator on
Linux fails on my midlet with a nullpointer in setCurrent. It is working
fine on the Emulator version in Windows as well as on the actual device.
Somebody got a clue?
Re: MTJ 0.9.1 on Linux vs. Nokia Phones [message #30093 is a reply to message #30057] Sun, 24 May 2009 16:11 Go to previous messageGo to next message
Hello Konstantin,
Follows some answers to your questions...
Konstantin Agouros wrote:
I guess you would be able to use the jar files with the javame libraries
but all executables such as the emulator itself would not run on linux
since they are native windows applications.
Assuming the nokia n90 is CLDC-1.1 MIDP-2.0 it should not have any
problem. Maybe there is no kvm installed on your device?? Does the same
JAD/JAR install on other devices ??
> Regards,
> Konstantin
What do you mean by "a nullpointer in setCurrent" ?? Is is the method
Display.setCurrent(...) ??
David Marques
Re: MTJ 0.9.1 on Linux vs. Nokia Phones [message #30130 is a reply to message #30093] Mon, 25 May 2009 03:01 Go to previous messageGo to next message
See below
David Marques wrote:
> Hello Konstantin,
>> Hi,
>> working fine, however I have two questions:
>> I can use it developing under Linux?
Yes this is what I meant. Develop with Nokia extensions so it compiles
and I get a JarFile that installs. And different Nokia Devices show up
in the device list. How do I do that?
>> the thing to CLDC-1.1 MIDP-2.0 so this should work or am I missing
>> something?
As I mentioned it works fine on Nokia E60/E50. According to the
UserAgent the N90 is 1.1/2.0 But Symbian 2.8 not 3.0 as the two E-Series
models I have my hands on.
>> Regards,
>> Konstantin
>> on Linux fails on my midlet with a nullpointer in setCurrent. It is
>> working fine on the Emulator version in Windows as well as on the
>> actual device. Somebody got a clue?
Yes. For whatever reason now it is working....
> Regards,
> David Marques
Re: MTJ 0.9.1 on Linux vs. Nokia Phones [message #30232 is a reply to message #30130] Mon, 25 May 2009 08:32 Go to previous messageGo to next message
Hi Konstantin,
The Unified Emulator Interface standard states that the SDKs must provide
an emulator executable (such as emulator.exe on Windows) that when
executed with the -Xquery option must list all available devices and it's
configurations so IDEs such as MTJ will retrieve the SDK's devices list.
As you only have the Windows emulator executable which can not be run on
Linux you will not be able to get integrated with MTJ.
Maybe you could try to run the 'emulator.exe -Xquery' on windows and get
the output then create a linux executable to print the same... It could
help you with getting the devices listed on MTJ. It is a *workaround*, i
have never done that... It is just a thought :) Still you will not be able
to run the emulator since it is a windows appliation :(
Maybe you should try other SDKs....
David Marques
> See below
>> Hello Konstantin,
>>> Hi,
>>> something?
>>> Regards,
>>> Konstantin
>> Regards,
>> David Marques
Re: MTJ 0.9.1 on Linux vs. Nokia Phones [message #30269 is a reply to message #30232] Mon, 25 May 2009 11:06 Go to previous message
> Hi Konstantin,
> provide an emulator executable (such as emulator.exe on Windows) that
> when executed with the -Xquery option must list all available devices
> and it's configurations so IDEs such as MTJ will retrieve the SDK's
> devices list. As you only have the Windows emulator executable which can
> not be run on Linux you will not be able to get integrated with MTJ.
> able to run the emulator since it is a windows appliation :(
Thanks for the clarification. Now I understand how it works and will
sadly have to get to a windows install to look if Nokia's APIs are even
worth the trouble.
Konstantin
Re: MTJ 0.9.1 on Linux vs. Nokia Phones [message #573004 is a reply to message #30057] Sun, 24 May 2009 16:11 Go to previous message
Hello Konstantin,
> Regards,
> Konstantin
David Marques
Re: MTJ 0.9.1 on Linux vs. Nokia Phones [message #573044 is a reply to message #30093] Mon, 25 May 2009 03:01 Go to previous message
See below
> Hello Konstantin,
>> Hi,
>> something?
>> Regards,
>> Konstantin
> Regards,
> David Marques
Re: MTJ 0.9.1 on Linux vs. Nokia Phones [message #573167 is a reply to message #30130] Mon, 25 May 2009 08:32 Go to previous message
Hi Konstantin,
David Marques
> See below
>> Hello Konstantin,
>>> Hi,
>>> something?
>>> Regards,
>>> Konstantin
>> Regards,
>> David Marques
Re: MTJ 0.9.1 on Linux vs. Nokia Phones [message #573226 is a reply to message #30232] Mon, 25 May 2009 11:06 Go to previous message
> Hi Konstantin,
worth the trouble.
Konstantin
Previous Topic:How to set Security-Level for the Emulator?
Next Topic:cannot import my WTK folder in the J2ME Device Management folder
Current Time: Sat Jul 19 14:02:09 EDT 2025
Powered by FUDForum. Page generated in 0.27353 seconds
