Home » Language IDEs » PHP Development Tools (PDT) » installing PDT
installing PDT [message #28385] Thu, 14 June 2007 09:26 Go to next message
Originally posted by: pobox.verysmall.org
Could somebody point to me an good resource about installing PDT. I use
Eclipse with PDT for several months now and the installation is always
pain. Currently I am stuck with PDT wanting org.eclipse.wst (2.0.0) and
the updater has access to WST 1.5.4 only. As far as I saw WST 2 is in
RC2 state. It's kind of inconvenient.
Iavor
Re: installing PDT [message #29977 is a reply to message #28385] Sun, 17 June 2007 06:43 Go to previous messageGo to next message
Latest PDT milestone package
( http://download.eclipse.org/tools/pdt/downloads/?release=S20 070611-M1)
depends on Eclipse 3.3 and WST 2,
which are not released yet. Try downloading the "PDT all in one" package.
"Iavor Raytchev" <pobox@verysmall.org> wrote in message
news:f4rfk2$3il$1@build.eclipse.org...
> the updater has access to WST 1.5.4 only. As far as I saw WST 2 is in RC2
> Iavor
Re: installing PDT [message #29992 is a reply to message #28385] Sun, 17 June 2007 12:50 Go to previous messageGo to next message
Originally posted by: omry.yadan.net
try this (worked for me today on eclipse 3.2):
1. add PDT update site.
2. in the software manager select PDT and Calisto discovery.
3. when you get the list of packages, select only PDT (not the SDK).
4. click on "select required", Eclipse should add EMF and its dependencies.
5. install.
> Iavor
Re: installing PDT [message #30781 is a reply to message #29977] Fri, 22 June 2007 08:14 Go to previous messageGo to next message
Yes. This exactly confused me - that the the PDT passed to the Updater
depends on things that are not accessible by the Updater. Isn't this
kind of bad practice?
Thanks, however, for the tip. This saves really a lot of time.
Iv
Re: installing PDT [message #32860 is a reply to message #28385] Mon, 02 July 2007 08:29 Go to previous messageGo to next message
PDT depends also on JEM (the visual editor, isn't it?) which is not
available from the europa update site, is it right?
Lorenzo Bettini, PhD in Computer Science, DSI, Univ. di Firenze
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: installing PDT [message #36453 is a reply to message #32860] Tue, 17 July 2007 10:21 Go to previous messageGo to next message
With Europa it was very easy to install PDT - everything is there. The
only problem is that before you press the button to select the required
packages - you must open the Europa tree. Otherwise it does not work.
Let me know if you have difficulties.
Re: installing PDT [message #36519 is a reply to message #36453] Tue, 17 July 2007 19:08 Go to previous messageGo to next message
when I tried to install it, I had the europa tree open but it still
couldn't find the required packages...
I'll try again now and see if anything changed...
Re: installing PDT [message #38020 is a reply to message #30781] Sun, 22 July 2007 08:06 Go to previous message
Originally posted by: slydder.arcor.de
I just gave up on updating the original eclipse I had installed (deb
package installed with apt-get in etch). No matter what I did I couldn't
get wst installed. Kept wanting things like xerces which is phased out
anyway so I deinstalled and installed the all in one package. Just now
got it running. Was hanging on the splash screen and wouldn't start. No
error messages at all just hangs. Now, all of a sudden, it works. Really
strange this package.
chuck
> Iv
Previous Topic:xdebug with pdt1.0
Next Topic:Problem with content assist (Template proposal)
Current Time: Sat Jul 19 07:58:59 EDT 2025
Powered by FUDForum. Page generated in 0.29268 seconds
