Home » Eclipse Projects » Eclipse Platform » I cannot run "Hello world" !
I cannot run "Hello world" ! [message #298202] Thu, 26 January 2006 10:36 Go to next message
Originally posted by: sanjay.krishna.us.fujitsu.com
This is embarassing. I have programmed in C/C++ for over 10 years and
tried to run a Java program using Eclipse on my dell laptop - Windows
2000. I really do not know what I am doing wrong. I did the following -
a) downloaded J2SE SDK including the run-time environment
b) downloaded Eclipse SDK.
c) I followed the procedure listed in the tutorial - New project, new
class etc.
Now whe I try to run (build automatically) - I click on the Run as - I get
a shaded "None applicable". Tried various things - could not get it to
work.
Could some one help me ?
Sanjay
Re: I cannot run "Hello world" ! [message #298206 is a reply to message #298202] Thu, 26 January 2006 10:50 Go to previous messageGo to next message
Originally posted by: gjipp_nospam.ca.ibm.com
Click the Run Icon pulldown menu and select "Run" to bring up the Run
Configuration dialog. You do not normally make any changes to the Main pane
except perhaps to select a different workspace. Make sure "Run a product"
is checked and org.eclipse.platform.ide is selected
The switch to the Plugin's pane and choose which plugins you want to run.
If you only have the one plugin project that's all that will be displayed in
the "workspace plugins" list. You can also choose to limit which of the
other Eclipse plugins are loaded in the test instance but you can leave them
all checked for now.
Then just press Run and watch a new Eclipse start up with a new blue icon
which is your extention
Hope that helps
"Sanjay Krishna" <sanjay.krishna@us.fujitsu.com> wrote in message
news:c63c25211fb4f7ba2f02116d0bd7fb8b$1@www.eclipse.org...
class etc.
work.
Sanjay
Re: I cannot run "Hello world" ! [message #298209 is a reply to message #298202] Thu, 26 January 2006 10:54 Go to previous messageGo to next message
Sorry, that was if you wanted to run a test plugin. The process is almost
the same is you want to run a class with a Main method. except you select
the application on the left tree control in the configuration dialog
class etc.
work.
Sanjay
Re: I cannot run "Hello world" ! [message #298210 is a reply to message #298209] Thu, 26 January 2006 10:56 Go to previous messageGo to next message
Or just select "Run As" and select Appication .
Remember, if you want to run a Java class you MUST have a Main method just
loike in C/C++
"Gary J" <gjipp_nospam@ca.ibm.com> wrote in message
news:drarbl$1jr$1@utils.eclipse.org...
class etc.
work.
Sanjay
Re: I cannot run "Hello world" ! [message #298233 is a reply to message #298210] Thu, 26 January 2006 17:10 Go to previous messageGo to next message
Sorry - I did try " Run As - Application" but in the options on the "Run
as" I do not see Application. I only get - "None applicable". Is my env
set up wrong ?
Sanjay
Re: I cannot run "Hello world" ! [message #298235 is a reply to message #298233] Thu, 26 January 2006 17:18 Go to previous messageGo to next message
--------------090109050903000907090808
Sanjay,
Did you right click on a class with a main() in it? It should work like
this without a hitch:
> "Run as" I do not see Application. I only get - "None applicable". Is
> my env set up wrong ?
> Sanjay
Content-Type: multipart/related;
boundary="------------010100060508030708030608"
--------------010100060508030708030608
<html>
<head>
http-equiv="Content-Type">
</head>
Sanjay,<br>
<br>
Re: I cannot run "Hello world" ! [message #298236 is a reply to message #298202] Thu, 26 January 2006 17:19 Go to previous messageGo to next message
> b) downloaded Eclipse SDK. c) I followed the procedure listed in the
> tutorial - New project, new class etc.
> get a shaded "None applicable". Tried various things - could not get it
> to work. Could some one help me ?
> Sanjay
Are you sure your class has a main() method with the proper signature?
public void main(String[] args) {
Eric
Re: I cannot run "Hello world" ! [message #298237 is a reply to message #298233] Thu, 26 January 2006 17:25 Go to previous messageGo to next message
> set up wrong ?
> Sanjay
Make sure you have created a Java Project, rather than a simple Project.
Also, make sure there are no compilation errors in the code.
Andrew Jr.
IBM Phoenix Labs (OTI)
2929 North Central Avenue
Phoenix, Arizona, USA 85012
Re: I cannot run "Hello world" ! [message #1711980 is a reply to message #298202] Tue, 20 October 2015 10:09 Go to previous message
I had the same exact problem my first time running it also. I noticed in the create class pane there was a check box [] inherited abstract methods, that was checked and REMAINED CHECKED after I checked [] main and I had the problem. So I deleted everything restarted and when I checked []main I unchecked [] inherited abstract methods, and then RUN AS had Java application selectable. I'm new too so I don't know what inherited abstract methods does (nor why, if your creating it now, it is something targeted in the past tense? {how could it have inherited anything, I didn't create it yet?}) but it kinda sounded like something a Main didn't want to do.
Previous Topic:Barcelona's Eclipse SDK not returning group model list
Next Topic:Problem with minimizing view
Current Time: Sat Jul 19 08:21:34 EDT 2025
Powered by FUDForum. Page generated in 0.18170 seconds
