Home » Eclipse Projects » Eclipse Platform » packaging icons with the plugin
packaging icons with the plugin [message #295734] Tue, 06 December 2005 09:34 Go to next message
I am developing a plugin which has some images on a few buttons... When
I add an image to represent for example, a view or a wizard in plugin.xml,
it gets added as "icons/someIcon.gif" but when i do the same thing for a
Button for example,
someButton.setImage(new Image(Display.getCurrent(),"icons/someImage.gif"));
it throws a file not found exception...How do I get over this, i.e. I
want these images to be displayed on a packaged and deployed plugin
Thanks in advance
Vijai
Re: packaging icons with the plugin [message #295736 is a reply to message #295734] Tue, 06 December 2005 09:52 Go to previous message
The problem is that for the plugin.xml it looks for the icons starting
in the root of the plugin.
But it is different for images for Buttons. new Image(display,filename)
looks for the image files in the current directory, which is NOT your
plugin.
Your images for buttons and such need to be in your library jar (i.e. in
the classpath of the plugin, not in the root directory of the plugin)
AND you need to use:
new Image(Display.getCurrent(), getClass().getResourceAsStream("/path to
file icon in jar"));
Also, you need to dispose of the image when you are done.
Vijai wrote:
> plugin.xml, it gets added as "icons/someIcon.gif" but when i do the same
> thing for a Button for example,
> Thanks in advance
> Vijai
Rich Kulp
Previous Topic:multiple applications
Next Topic:Graceful shutdown of Java Applications
Current Time: Sat Jul 19 14:46:59 EDT 2025
Powered by FUDForum. Page generated in 0.03161 seconds
