Home » Eclipse Projects » Eclipse Platform » EditorInput Constructor Being called twice
EditorInput Constructor Being called twice [message #292603] Fri, 07 October 2005 16:40 Go to next message
I create an instance of an EditorInput
IEditor input = new EditorInput();
and then call
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().openEditor(input,
editorID);
to open the editor.
the openEditor calls the constructor again. Does this mean their are
two instances of the editorInput?
Re: EditorInput Constructor Being called twice [message #292650 is a reply to message #292603] Mon, 10 October 2005 06:19 Go to previous messageGo to next message
Originally posted by: daniel.megert.eclipse.org
James Leotta wrote:
> Hello,
This is code not possible since there's now such thing as EditorInput
class in Eclipse SDK. Is this your own implementation of IEditorInput or
did you mean FileEditorInput?
Dani
> and then call
> editorID);
> to open the editor.
Re: EditorInput Constructor Being called twice [message #292662 is a reply to message #292650] Mon, 10 October 2005 11:45 Go to previous messageGo to next message
Its my own class here is the method I am calling
public void getEditor(Object obj){
String editorID = null;
IEditorPart editor = null;
IEditorInput input = null;
if (obj instanceof Agency){
input = new AgencyEditorInput((Agency) obj);
editorID = AgencyEditor.ID;
if (obj instanceof AMITables){
//input = new AgencyEditorInput((Agency) obj);
//editorID = AgencyEditor.ID;
if (obj instanceof Grant){
input = new GrantEditorInput((Grant) obj);
editorID = GrantEditor.ID;
if (obj instanceof Employee){
input = new StaffEditorInput((Employee) obj);
editorID = StaffEditor.ID;
if (obj instanceof County){
if (obj instanceof User){
input = new UserEditorInput((User) obj);
editorID = UserEditor.ID;
editor =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().findEditor(input);
if (editor != null){
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().activate(editor);
return;
try{
editorID);
}catch(Exception e){
System.out.println(e);
Daniel Megert wrote:
> James Leotta wrote:
>> Hello,
> Dani
>> and then call
>> editorID);
>> to open the editor.
Re: EditorInput Constructor Being called twice [message #292663 is a reply to message #292662] Mon, 10 October 2005 11:58 Go to previous message
Put a breakpoint into the constructor and check who's calling it.
Dani
> editor =
> return;
> try{
> editorID);
>> James Leotta wrote:
>>> Hello,
>> or did you mean FileEditorInput?
>> Dani
>>> and then call
>>> editorID);
>>> to open the editor.
>>> are two instances of the editorInput?
Previous Topic:Key Bindings
Next Topic:Infopop
Current Time: Sun Jul 20 14:53:19 EDT 2025
Powered by FUDForum. Page generated in 0.04070 seconds
