Home » Eclipse Projects » Babel » Is it possible to get the dates/time in a specific locale but not the translations from that locale?
Is it possible to get the dates/time in a specific locale but not the translations from that locale? [message #29051] Tue, 09 June 2009 10:48 Go to next message
Originally posted by: w.roeckelein.begis.com
is it possible to get the dates/time in a specific locale but not the translations from that locale?
eg. have german style date/time but all UI text in english, ie no translations, esp not translations from features/plugins which have translations inside.
Wolfgang
Re: Is it possible to get the dates/time in a specific locale but not the translations from that loc [message #29091 is a reply to message #29051] Mon, 15 June 2009 18:30 Go to previous messageGo to next message
Most Eclipse project calls ICU4J and Java APIs to get time and date info.
If you launch Eclipse with no language pack installed with "-nl de" option
(no quotes), Eclipse will use German time and date info.
I created a new project and the last modifed time stamp was: 15. Juni 2009
18:20:59
Everything else was in English.
Re: Is it possible to get the dates/time in a specific locale but not the translations from that loc [message #29123 is a reply to message #29091] Mon, 22 June 2009 01:53 Go to previous messageGo to next message
> info. If you launch Eclipse with no language pack installed with "-nl
> de" option (no quotes), Eclipse will use German time and date info.
Yes, but all plugins who bring in their own localization will be in German then,
so I have a nice mixture of english and german then...
Wolfgang
Re: Is it possible to get the dates/time in a specific locale but not the translations from that loc [message #29160 is a reply to message #29123] Mon, 22 June 2009 11:19 Go to previous messageGo to next message
then,
I can think of 2 options:
1) In Eclipse software configuration, you may disable the language
fragments for those plugins
2) Assuming that you are on Windows (Linux should have similiar setup),
you may set the system locale to English, but customize the date and time
format in Regional Options to German
Re: Is it possible to get the dates/time in a specific locale but not the translations from that loc [message #29198 is a reply to message #29160] Tue, 23 June 2009 04:09 Go to previous messageGo to next message
>> German
> then,
> time format in Regional Options to German
Will try that and report results.
Wolfgang
Re: Is it possible to get the dates/time in a specific locale but not the translations from that loc [message #29236 is a reply to message #29160] Thu, 25 June 2009 12:34 Go to previous messageGo to next message
>> German
> then,
at least eg. on 3.3 for com.essiembre.eclipse.i18n.resourcebundle_0.7.7.200809291519 .jar
from the http://www.nightlabs.de/updatesites/development/ update site
the localized messages properties are just inside this plugin jar, so I can't see how to do this...
Wolfgang
Re: Is it possible to get the dates/time in a specific locale but not the translations from that loc [message #29274 is a reply to message #29236] Sat, 27 June 2009 15:49 Go to previous messageGo to next message
If a plugin does not separate their localized messages into a plugin
fragment, I can't think of a way to get around that either.
Re: Is it possible to get the dates/time in a specific locale but not the translations from that loc [message #29311 is a reply to message #29051] Sun, 28 June 2009 07:33 Go to previous message
Do you want to format the date/time in your own application or wish to do so
in Eclipse IDE?
I believe in some OSs you may also do so on a lower level, I remember even
using UK keyboard or date/time format in Dubai or Switzerland (even though
the language was German or US English)
In your own code, using Java DateFormat with a Locale different than the
default would do the trick.
Werner
Re: Is it possible to get the dates/time in a specific locale but not the translations from that loc [message #578947 is a reply to message #29051] Mon, 15 June 2009 18:30 Go to previous message
18:20:59
Re: Is it possible to get the dates/time in a specific locale but not the translations from that loc [message #578976 is a reply to message #29091] Mon, 22 June 2009 01:53 Go to previous message
Wolfgang
Re: Is it possible to get the dates/time in a specific locale but not the translations from that loc [message #578991 is a reply to message #29123] Mon, 22 June 2009 11:19 Go to previous message
then,
Re: Is it possible to get the dates/time in a specific locale but not the translations from that loc [message #579021 is a reply to message #29160] Tue, 23 June 2009 04:09 Go to previous message
>> German
> then,
Wolfgang
Re: Is it possible to get the dates/time in a specific locale but not the translations from that loc [message #579039 is a reply to message #29160] Thu, 25 June 2009 12:34 Go to previous message
>> German
> then,
Wolfgang
Re: Is it possible to get the dates/time in a specific locale but not the translations from that loc [message #579061 is a reply to message #29236] Sat, 27 June 2009 15:49 Go to previous message
Re: Is it possible to get the dates/time in a specific locale but not the translations from that loc [message #579083 is a reply to message #29051] Sun, 28 June 2009 07:33 Go to previous message
in Eclipse IDE?
Werner
Previous Topic:Is it possible to get the dates/time in a specific locale but not the translations from that locale?
Next Topic:Missing/Changed Galileo Update Sites?!
Current Time: Sat Jul 19 09:15:26 EDT 2025
Powered by FUDForum. Page generated in 0.06714 seconds
