Home » Eclipse Projects » Eclipse Platform » Disabling the welcome view
Disabling the welcome view [message #289979] Tue, 16 August 2005 09:20 Go to next message
I would like to disable the new welcome view in our eclipse-based
offering, so that after the splash screen vanishes, our users will get
straight to the workbench (preferably to our perspective). I know I can
set the default perspective using a command line argument, but how can I
disable the welcome view?
Thanks in advance,
- Eran B.
Re: Disabling the welcome view [message #290043 is a reply to message #289979] Thu, 18 August 2005 01:17 Go to previous messageGo to next message
U can try with the code below..
IWorkbench workbench = PlatformUI.getWorkbench();
IWorkbenchWindow window = workbench.getActiveWorkbenchWindow();
IWorkbenchPage page = window.getActivePage();
IViewReference[] viewRefs = page.getViewReferences();
// this will give u all the view references..
// so run a for loop and check for the introview id , that is nothing but
the welcome page id...
if (viewRefs[i].getId().equals("org.eclipse.ui.internal.introview ")) {
IViewPart part = page.findView("org.eclipse.ui.internal.introview");
page.hideView(part); // this will hide the view...
Re: Disabling the welcome view [message #290069 is a reply to message #290043] Thu, 18 August 2005 07:13 Go to previous messageGo to next message
Thanks! worked like a charm!
- Eran B.
Re: Disabling the welcome view [message #304554 is a reply to message #290043] Fri, 09 June 2006 11:43 Go to previous message
Where should this code be?
"Babu" <manohar.babu@gmail.com> a
Previous Topic:Using base content describers when extending content type.
Next Topic:Disabling ActionSetPartAssociations of other plugins
Current Time: Sun Jul 20 13:00:16 EDT 2025
Powered by FUDForum. Page generated in 0.04181 seconds
