Home » Eclipse Projects » Eclipse Platform » Key binding for action in Eclipse 3.1 ?
Key binding for action in Eclipse 3.1 ? [message #289198] Tue, 02 August 2005 03:58 Go to next message
I would like to bind a keyboard shortcut to one of my actions. This
particular action is a refactoring operation ("Rename...") that operates
on a custom editor that I've implemented myself. This operation is
located in the "Source" menu, which is only visible when an instance of
the custom editor is active.
This is was my best guess so far, I added this to plugin.xml
<extension point="org.eclipse.ui.bindings">
<key sequence="F2"
commandId="defid.source.menu.Rename"
schemeId="org.eclipse.ui.defaultAcceleratorConfiguration">
</key>
</extension>
But this did not work. Even though I see the action in the source menu
(and can use it by clicking on it), nothing happens when I click the F2
button. Nor does any key binding label appear next to the "Rename..."
menu item.
I've read about a zillion different ways to add key bindings to actions.
Which method is the latest one? I'm using Eclipse 3.1 at the moment.
regards,
martin
Re: Key binding for action in Eclipse 3.1 ? [message #289216 is a reply to message #289198] Tue, 02 August 2005 09:47 Go to previous messageGo to next message
I'm not quite shure if the problem is that you are trying to override a
keybinding from org.eclipse.ui plugin or that you are using action id
instead of command id in the binding.
generally speaking - you need to define a command (an extension to
org.eclipse.ui.commands extension point) in your plugin witht the same
ID as commandId attribute value, and specify the same id as definitionId
for your action definition.
The code should look something like this:
<extension point="org.eclipse.ui.commands">
<command id="defid.source.menu.Rename"
name="Rename"
categoryId="Your.category.id"/>
</extension>
<key sequence="F2"
</key>
</extension>
<extension point="org.eclipse.ui.actionSets">
<actionSet ...>
<action id="..."
definitionId="defid.source.menu.Rename"
</actionSet>
</extension>
(excuse me if there are typos or I've missed something - the exact
syntax is described in documentation for each extensionpoint)
Martin Olsson kirjutas mulle ühel talvisel päeval midagi seesugust:
> <key sequence="F2"
> </key>
> </extension>
> menu item.
> regards,
> martin
Roland Tepp
Re: Key binding for action in Eclipse 3.1 ? [message #289428 is a reply to message #289216] Thu, 04 August 2005 20:57 Go to previous messageGo to next message
Originally posted by: user.domain.invalid
Thanks R. That worked right away. Looks like my bindings where colliding
with other JDT bindings just as you suggested. Again... Thanks!
Sincerly,
Martin
> name="Rename"
> </extension>
> <key sequence="F2"
> </key>
> </extension>
> <actionSet ...>
> <action id="..."
> </actionSet>
> </extension>
>> operates on a custom editor that I've implemented myself. This
>> operation is located in the "Source" menu, which is only visible when
>> an instance of the custom editor is active.
>> <key sequence="F2"
>> </key>
>> </extension>
>> F2 button. Nor does any key binding label appear next to the
>> "Rename..." menu item.
>> actions. Which method is the latest one? I'm using Eclipse 3.1 at the
>> moment.
>> regards,
>> martin
Re: Key binding for action in Eclipse 3.1 ? [message #289441 is a reply to message #289216] Thu, 04 August 2005 18:59 Go to previous messageGo to next message
What is proper procedure, if some plugin defines a key binding "too
broadly", and you'd like to use the same binding subset context?
David
Re: Key binding for action in Eclipse 3.1 ? [message #289466 is a reply to message #289441] Fri, 05 August 2005 08:02 Go to previous messageGo to next message
Let's say the example is F5 -> Refresh. If you are simply going to
implement functionality that has the same semantic as "refresh" but
localized to the particular context, then you should just override the
handler.
If you are going to change the meaning entirely (e.g., Step Into), then you
define a context. The context should be a child of the context containing
the binding you wish to override. In this way, your binding will be given
priority.
The F5 example is a good one for overriding by context. Cut/copy/paste are
good examples of providing a different handler.
d.
Re: Key binding for action in Eclipse 3.1 ? [message #289509 is a reply to message #289466] Fri, 05 August 2005 20:19 Go to previous messageGo to next message
> handler.
> you
> priority.
> are good examples of providing a different handler.
The specific case I'm talking about is "CTRL-ALT-X T" Run as JUnit Test. I
want to use it for "Run as Test::Unit Test" if the "selection" is
appropriate (since I don't think the currently selected thing can be both
Java and Ruby at the same time).
I'll look at the context definition.
Thanks.
> d.
Re: Key binding for action in Eclipse 3.1 ? [message #289564 is a reply to message #289466] Mon, 08 August 2005 07:55 Go to previous messageGo to next message
Ok, but how do I control what is the curtrent application context?
Douglas Pollock kirjutas mulle ühel talvisel päeval midagi seesugust:
> handler.
> priority.
> d.
Roland Tepp
Re: Key binding for action in Eclipse 3.1 ? [message #289576 is a reply to message #289564] Mon, 08 August 2005 09:43 Go to previous message
Originally posted by: sunil_kamath.nohotspammail.com
"Roland Tepp" <roland@videobet.com> wrote in message
news:dd7h76$aps$1@news.eclipse.org...
Previous Topic:How to register a key binding to a IAction
Next Topic:SourceViewConfiguration
Current Time: Sat Jul 19 15:43:19 EDT 2025
Powered by FUDForum. Page generated in 0.08021 seconds
