Home » Eclipse Projects » Eclipse Platform » How can I write to the status line bar?
How can I write to the status line bar? [message #289182] Mon, 01 August 2005 11:54 Go to next message
Originally posted by: mendoza.anafocus.com
Hello.
Can anyone please tell me how to write to the status line bar from my
plug-in?
Thanks.
Re: How can I write to the status line bar? [message #289184 is a reply to message #289182] Mon, 01 August 2005 12:39 Go to previous messageGo to next message
Originally posted by: sunil_kamath.nohotspammail.com
"Carlos" <mendoza@anafocus.com> wrote in message
news:0ecc2a95564d9b0fbd3a3675ba887205$1@www.eclipse.org...
> Hello.
> plug-in?
> Thanks.
org.eclipse.ui.texteditor.StatusLineContributionItem
Sunil
Re: How can I write to the status line bar? [message #289201 is a reply to message #289184] Tue, 02 August 2005 05:32 Go to previous messageGo to next message
If you don't need any text editor and don't want to depend
on the bundle of plugins that org.eclipse.ui.texteditor implies
there's no way (I know of) but to copy the source of
StatusLineContributionItem and save it as a local class.
That class is way too simple and basically is a somthing
non-editor specific that it should be refactored.
Marcus
Re: How can I write to the status line bar? [message #289388 is a reply to message #289201] Thu, 04 August 2005 06:23 Go to previous messageGo to next message
> Marcus
Thanks.
I've also found that you only need to do this in order to write to the
status line bar from a view:
getViewSite().getActionBars().getStatusLineManager().setMess age( "Hello");
or from an editor:
getEditorSite().getActionBars().getStatusLineManager().setMe ssage( "Hello");
I guess StatusLineContributionItem is useful when you want to customize
the status line bar.
Re: How can I write to the status line bar? [message #289411 is a reply to message #289388] Thu, 04 August 2005 09:37 Go to previous messageGo to next message
news:f57400a6ea94c8cafcfac11509229b4a$1@www.eclipse.org...
> [snip]
> or from an editor:
Yes, otherwise there is no guarantee that your message won't get overwritten
immediately by some other component.
Sunil
Re: How can I write to the status line bar? [message #289457 is a reply to message #289388] Fri, 05 August 2005 06:08 Go to previous messageGo to next message
Originally posted by: vducloux.cosmosbay-vectis.com
Hi, I have tried this and it works perfect. I instead set an Error
Message. thanks for the help.
But know how can make it disappear after like 3 seconds ?
thnaks in advance for the help,
>> Marcus
> Thanks.
> or from an editor:
Re: How can I write to the status line bar? [message #289459 is a reply to message #289457] Fri, 05 August 2005 06:22 Go to previous message
>>> Marcus
>> Thanks.
>> or from an editor:
>> customize the status line bar.
Use a seperate thread to set the statusbar to blank after 3 seconds.
Remember to use asynchExec or syncExec on Display for updating the
statusbar in your thread.
Stefan
Previous Topic:Performance Tests package - where can I get it ?
Next Topic:Searching for documentation about launching the OSGi framework...
Current Time: Sat Jul 19 18:38:53 EDT 2025
Powered by FUDForum. Page generated in 0.04464 seconds
