Home » Eclipse Projects » Eclipse Platform » Eclipse is suddenly freezed
Eclipse is suddenly freezed [message #286129] Thu, 02 June 2005 22:39 Go to next message
Originally posted by: doanphihai.yahoo.com
Hi all,
When I work in Eclipse 3.1M7 (also Eclipse 3.1RC), Eclipse is suddenly
freezed in few minutes when I try to use "Open Declaration" (got the same
bug when use F3 key to do that). Is that a bug or wrong configuration? Who
can help me work around this case?
Thanks a lot,
--P.H
Re: Eclipse is suddenly freezed [message #286131 is a reply to message #286129] Thu, 02 June 2005 23:07 Go to previous messageGo to next message
HaiDoan wrote:
> Hi all,
> same bug when use F3 key to do that). Is that a bug or wrong
> configuration? Who can help me work around this case?
most likely: too little heap memory
try running eclipse with option -vmargs -Xmx300M to give it 300
Megabytes (or try more if you want)
/adam
Re: Eclipse is suddenly freezed [message #286133 is a reply to message #286131] Thu, 02 June 2005 23:35 Go to previous messageGo to next message
Now heapsize is 400M, and it still got that bug. Oh I miss something,
there is one linked forder in my project, it just point to a folder in
local hardisk. Does it make that error?
Re: Eclipse is suddenly freezed [message #286134 is a reply to message #286129] Thu, 02 June 2005 23:42 Go to previous messageGo to next message
Luckily I finished it, I can't believe that, you know what? I change to
use JDK_1.4.2_08 (old case is Tiger 1.5.0.03?? can't remmember exactly but
whatever :-)). Why it like that, since it does not happen in Eclipse302.
OMG
Re: Eclipse is suddenly freezed [message #286136 is a reply to message #286134] Thu, 02 June 2005 23:52 Go to previous messageGo to next message
so early to happy, the bug is still there, man. Now I don't know what is
wrong?
Re: Eclipse is suddenly freezed [message #286137 is a reply to message #286136] Thu, 02 June 2005 23:59 Go to previous messageGo to next message
> wrong?
what OS?
on unix you can send SIGQUIT to the vm to get the thread dump
/adam
Re: Eclipse is suddenly freezed [message #286138 is a reply to message #286133] Fri, 03 June 2005 00:02 Go to previous messageGo to next message
don;t know. if you think it might, try removing the link and see if the
problem is still there
/adam
Re: Eclipse is suddenly freezed [message #286139 is a reply to message #286137] Fri, 03 June 2005 00:07 Go to previous messageGo to next message
I use Windows 2000. Does it lead to the bug?
Re: Eclipse is suddenly freezed [message #286141 is a reply to message #286139] Fri, 03 June 2005 01:10 Go to previous message
i don't think so, i used w2k for a long time with no problems.
/adam
Previous Topic:Eclipse is slow to shutdown
Next Topic:A plugin backed by XML
Current Time: Sat Jul 19 16:23:28 EDT 2025
Powered by FUDForum. Page generated in 0.11369 seconds
