Home » Eclipse Projects » Subversive » Ignored Resources ignored?
Ignored Resources ignored? [message #27308] Fri, 01 August 2008 05:31 Go to next message
I have installed Subversive 0.7.1.I20080612-1500 and Eclipse Ganymede on
my computer. Everything works fine excepting the ignored resources. I
have one project in the svn which holds all data including several
eclipse java projects. So I had to add "bin" to the ignored resources to
exclude these directories from version control. But that does not work.
After the recompilation of the projects the bin directory is added to
the version control and all subdirectories and files are marked with a
red exclamation. After a restart of eclipse and a svn re-synchronize
everythinkg is fine, until the next recompilation.
Has someone a hint if that is a misconfiguration or a bug?
Greetings
Adam
Re: Ignored Resources ignored? [message #27762 is a reply to message #27308] Fri, 01 August 2008 06:09 Go to previous messageGo to next message
Originally posted by: alexander.gurov.polarion.org
Hello Adam,
Did you have "bin" folder already committed to the source control or not
(if so, "bin" folder should be decorated with the orange "barrel")? In
that case you should first remove "bin" folder from the repository in
order to allows svn:ignore processing for it.
Also Subversive provides feature which allows to automatically exclude
output folder from the commit set. This feature is called "JDT Ignore
Extensions (Optional) (Incubation)" and it also works only if output
folder is not under source control.
P.S.
In my environment (after installing of the JDT Ignore feature) I haven't
any problems with the output folders ignoring even if I have no "bin"
folder specified in the svn:ignore property.
Re: Ignored Resources ignored? [message #27839 is a reply to message #27762] Fri, 01 August 2008 06:26 Go to previous messageGo to next message
Hello Alexander,
the "bin" folders are not committed to the svn and the mentioned "JDT
Ignore Extensions" is also installed. I cannot add the several bin
folders explicit by the contextmenu in the team perspective because the
bin folder is not shown. Additionally, it has already a .svn folder in
the bin folder. I guess that the red exclamations are a consequence of
the fact that the bin folders are not in the repository but has datas in
the .svn folder. And I have already checked out everything more than one
times from the scratch to check synchronization failures.
Another point is, that the bin folder is ignored if I delete the proper
..svn folder until the next recompilation.
Any suggestions what I could check? Or what went wrong?
Adam
Alexander Gurov schrieb:
> Hello Adam,
>> on my computer. Everything works fine excepting the ignored resources.
>> I have one project in the svn which holds all data including several
>> to exclude these directories from version control. But that does not
>> work.
> P.S.
Re: Ignored Resources ignored? [message #27879 is a reply to message #27839] Fri, 01 August 2008 06:54 Go to previous messageGo to next message
It looks like you use external build process which copies existsing .svn
folders from the source folders to the corresponding output folders (I
think in this way because built-in Eclipse builder ignores team private
resources like .svn). This mean that in order to avoid the problem you
should exclude .svn folders from your build process.
Re: Ignored Resources ignored? [message #27998 is a reply to message #27879] Fri, 01 August 2008 07:54 Go to previous message
that seems to be the hint which I was needed. I will give a try with
that. Thank you.
Adam
Previous Topic:SVNkit plug-ins
Next Topic:Label Decorations
Current Time: Sat Jul 19 09:19:23 EDT 2025
Powered by FUDForum. Page generated in 0.05066 seconds
