Home » Eclipse Projects » Eclipse Platform » Java 1.5/5.0 now!
Java 1.5/5.0 now! [message #272595] Thu, 23 September 2004 19:18 Go to next message
Originally posted by: overbored.overbored.net
Is it possible to get Java 1.5/5.0 for Eclipse right now? I know it's under
development (as is Sun's JDK), but if it's stable enough, I'd like to use
it ASAP. The only things I'd use from Java 5 for now are generics, auto-
boxing, the new for loop, and maybe printf - basically, none of the
advanced/non-language-sugarcoating features. If it supports these, how do I
get it? All I've been able to find on this is
http://www.vasanthdharmaraj.com/PermaLink,guid,be41926c-4d38 -4c16-a273-
6f586c00de11.aspx, but I'm afraid to follow this as it's outdated and
provides me with no info on how well the JDT would suit my needs in its
current state. Thanks in advance.
Re: Java 1.5/5.0 now! [message #272596 is a reply to message #272595] Thu, 23 September 2004 19:52 Go to previous messageGo to next message
The plan for the Eclipse support is available here:
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/jdt- core-home/r3.1/main.html#release-plan
or
Download the latest 3.1 release (M2 is coming out at the end of this week)
and try it :-). The cheetah support mentioned on the blog has been rolled in
to the main 3.1 stream and is being worked on there.
HTH
Darins
"overbored" <overbored@overbored.net> wrote in message
news:Xns956DA6B42D810yangstaoverbored@204.138.98.10...
under
I
Re: Java 1.5/5.0 now! [message #272614 is a reply to message #272596] Fri, 24 September 2004 05:45 Go to previous messageGo to next message
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in
news:civndk$86d$1@eclipse.org:
home/r
Um...so, does this just not support any of the features I mentioned, or
do I have to configure something? I'm running 3.1 and I set the compiler
compliance to 1.5, but when I do:
Vector<int> v;
or
Vector v;
int x;
v.add(x);
I get errors.
Re: Java 1.5/5.0 now! [message #272619 is a reply to message #272614] Fri, 24 September 2004 07:11 Go to previous messageGo to next message
> Vector<int> v;
> I get errors.
We've been using generics with Cheetah and now Eclipse 3.1 (M1) for some
months now, and they work fine here.
Re: Java 1.5/5.0 now! [message #272620 is a reply to message #272614] Fri, 24 September 2004 07:16 Go to previous messageGo to next message
What I read from the plan is:
- generic support is being developed,
- enhanced for loops work is completed
- enumeration, autoboxing, static imports, metadata work has not yet started
Jerome
news:Xns956E1CD82BDCyangstaoverbored@204.138.98.10...
> home/r
> Vector<int> v;
> or
> Vector v;
> int x;
> v.add(x);
> I get errors.
Re: Java 1.5/5.0 now! [message #272627 is a reply to message #272620] Fri, 24 September 2004 08:52 Go to previous messageGo to next message
Enums definitely don't work in 3.1M1. You can declare them OK but any
attempt to use them results in errors. I'm hoping they will be in M2 which
is due out today or tomorrow but I don't know.
Steve
"Jerome Lanneluc" <jerome_lanneluc@fr.ibm.com> wrote in message
news:cj0vdu$5nh$1@eclipse.org...
started
> Jerome
> > home/r
> > Vector<int> v;
> > or
> > Vector v;
> > int x;
> > v.add(x);
> > I get errors.
Re: Java 1.5/5.0 now! [message #272628 is a reply to message #272627] Fri, 24 September 2004 09:00 Go to previous messageGo to next message
OK, I was not clear enough. All the 1.5 constructs can be parsed (in 3.1 M1
and M2) but parsing is only part of the work. The real work (resolution,
flow analysis, code gen, etc ) to support enumeration, autoboxing, static
imports, metadata work has not yet started.
Jerome
"Steven Buroff" <sburoff@optonline.net> wrote in message
news:cj1523$grj$1@eclipse.org...
> Steve
> started
> > Jerome
> > > home/r
or
compiler
> > > Vector<int> v;
> > > or
> > > Vector v;
> > > int x;
> > > v.add(x);
> > > I get errors.
Re: Java 1.5/5.0 now! [message #272629 is a reply to message #272614] Fri, 24 September 2004 09:26 Go to previous message
> Vector<int> v;
> or
> Vector v;
> int x;
> v.add(x);
> I get errors.
Make sure you've set up an 1.5 JRE to compile against. Furthermore, the type
Vector<int> is not valid - primitive types cannot be used as generic type
parameters.
Markus
Previous Topic:[ANN] OrindaBuild 4.0 Oracle JDBC code generator released as Plugin
Next Topic:IResourceChangeListener adding at IDE startup
Current Time: Sat Jul 19 19:56:37 EDT 2025
Powered by FUDForum. Page generated in 0.05376 seconds
