Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » problem installing ocl
problem installing ocl [message #27149] |
Mon, 06 March 2006 09:00  |
My versions:
eclipse 3.2M5 for linux
emf-xsd-sdo 2.2.0M5
ocl 1.0.0M5 (stable build)
antl.jar 2.7.2 copied into antl.../lib as per readme.
When I start up eclipse, it lists ocl as a plugin, yet there is no
evidence of ocl in the workbench (eg, New-->Other-->EMF Examples ...
does not show any ocl-related wizard). The .metadata/.log shows no errors.
What am I overlooking?
- C
Re: problem installing ocl [message #27188 is a reply to message #27149] |
Mon, 06 March 2006 09:13   |
Hi, Christopher,
The OCL examples are manifest only in the editor and context menus for the
EXTLibrary Example Editor. In the "File -> New -> Other..." dialog, choose
"Example EMF Model Creation Wizards / EXTLibrary Model". The Library is
the most useful root element to choose.
In this editor, you will see various OCL actions in the menus, depending on
how many of the EMFT components you have installed.
HTH,
Christian
Christopher Gibblin wrote:
> My versions:
> emf-xsd-sdo 2.2.0M5
> - C
Re: problem installing ocl [message #27226 is a reply to message #27188] |
Mon, 06 March 2006 09:28   |
Hi Christian,
I still have a problem.
When I do "File -> New -> Other -> Example EMF Model Creation Wizards",
"EXTLibrary Model" does not appear as an option, rather only the usual
EMF creation wizards (eg, "Ecore model") appear. This suggests to me
that OCL is not properly installed, however, Eclipse -> Help -> Plugins
shows "Eclipse Modeling Framework Technology OCL Interpreter". And as I
mentioned, there are no errors in the Eclipse log.
There must be something fundamental about installing plugins into
Eclipse 3.2 which I am missing. I unzipped the plugins onto my eclipse
directory, seeing as the plugin contents have relative paths beginning
with "eclipse".
-C
Christian W. Damus wrote:
> Hi, Christopher,
> HTH,
> Christian
>> Hi,
>> My versions:
>> emf-xsd-sdo 2.2.0M5
>> Thanks,
>> - C
Re: problem installing ocl [message #27263 is a reply to message #27226] |
Mon, 06 March 2006 09:34   |
Christopher,
Did you install the EMF examples feature? It's a separate download from
the SDK feature...
> Hi Christian,
> Wizards", "EXTLibrary Model" does not appear as an option, rather
> only the usual EMF creation wizards (eg, "Ecore model") appear. This
> suggests to me that OCL is not properly installed, however, Eclipse
> -> Help -> Plugins shows "Eclipse Modeling Framework Technology OCL
> Interpreter". And as I mentioned, there are no errors in the Eclipse
> log.
> with "eclipse".
> -C
>> Hi, Christopher,
>> for the
>> choose
>> depending on
>> HTH,
>> Christian
>>> Hi,
>>> My versions:
>>> emf-xsd-sdo 2.2.0M5
>>> errors.
>>> Thanks,
>>> - C
Re: problem installing ocl [message #27298 is a reply to message #27263] |
Mon, 06 March 2006 11:53  |
Ed,
Thanks. That did it.
I guess my config was ok in the first place. I had just expected to see
something the interactive OCL console as a view in Window->Show View.
Installing the EMF samples gave me the opportunity to see the available
OCL actions.
Thanks, chris
Ed Merks wrote:
> Christopher,
> the SDK feature...
>> Hi Christian,
>> log.
>> with "eclipse".
>> Thanks,
>> -C
>>> Hi, Christopher,
>>> for the
>>> choose
>>> depending on
>>> HTH,
>>> Christian
>>>> Hi,
>>>> My versions:
>>>> emf-xsd-sdo 2.2.0M5
>>>> errors.
>>>> Thanks,
>>>> - C
Re: problem installing ocl [message #571399 is a reply to message #27149] |
Hi, Christopher,
HTH,
Christian
> My versions:
> emf-xsd-sdo 2.2.0M5
> - C
Re: problem installing ocl [message #571430 is a reply to message #27188] |
Hi Christian,
with "eclipse".
-C
> Hi, Christopher,
> HTH,
> Christian
>> Hi,
>> My versions:
>> emf-xsd-sdo 2.2.0M5
>> Thanks,
>> - C
Re: problem installing ocl [message #571464 is a reply to message #27226] |
Christopher,
the SDK feature...
> Hi Christian,
> log.
> with "eclipse".
> -C
>> Hi, Christopher,
>> for the
>> choose
>> depending on
>> HTH,
>> Christian
>>> Hi,
>>> My versions:
>>> emf-xsd-sdo 2.2.0M5
>>> errors.
>>> Thanks,
>>> - C
Re: problem installing ocl [message #571496 is a reply to message #27263] |
Ed,
OCL actions.
Thanks, chris
Ed Merks wrote:
> Christopher,
> the SDK feature...
>> Hi Christian,
>> log.
>> with "eclipse".
>> Thanks,
>> -C
>>> Hi, Christopher,
>>> for the
>>> choose
>>> depending on
>>> HTH,
>>> Christian
>>>> Hi,
>>>> My versions:
>>>> emf-xsd-sdo 2.2.0M5
>>>> errors.
>>>> Thanks,
>>>> - C
Current Time: Sat Jul 19 16:32:23 EDT 2025
Powered by FUDForum. Page generated in 0.25694 seconds
