Home » Eclipse Projects » Eclipse Platform » How to set up the source folders of a project
How to set up the source folders of a project [message #270571] Wed, 08 September 2004 03:58 Go to next message
Originally posted by: afluegge.vitria.com
I need to setup an uncommon source folder structure. The structure of that
folder is dictated by an other tool that shares the files of this project.
Here is the folder structure to use:
<Project Root>
<...some folders>
com
... (rest of the package structure)
<... some more folders>
GeneratedTypes
com
What I need to setup is the "<Project Root>/com" folder and the "<Project
Root>/GeneratedTypes/..." folder as source folders. So far I get the error
that it is not possible to nest the "GeneratedTypes" folders into the "com"
folder. Any trick to make Eclipse accept both the project root as well as
the GeneratedTypes folders as root folders for source files?
Andreas
Re: How to set up the source folders of a project [message #270600 is a reply to message #270571] Wed, 08 September 2004 09:54 Go to previous message
Originally posted by: daniel.megert.gmx.net
Andreas Fluegge wrote:
>Hello,
><Project Root>
> <...some folders>
> com
> GeneratedTypes
> com
Not sure what Eclipse version you use. In 3.0 you can simply exclude the
first folder of <... some more folders...> from the project source
folder entry.
Dani
>Andreas
Previous Topic:Contribute action to JavaEditor popup menu
Next Topic:MultiPageEditorPart in org.eclipse.ui.ide prevents RCP use
Current Time: Sun Jul 20 13:08:55 EDT 2025
Powered by FUDForum. Page generated in 0.03396 seconds
