Home » Newcomers » Newcomers » Working on a File from the File System Directly
Working on a File from the File System Directly [message #269982] Sun, 05 April 2009 02:51 Go to next message
I have a xml file and i have developed an editor which will show the
contents of it graphically.
The problem is that any user will have that file somewhere in their file
system..and i want to give provision for the user to select the file
dynamically and work on it..
When i unmarshall the xml file i need to provide the file as a string,
located in the file system..
Can anyone suggest something??
Adithya.
Re: Working on a File from the File System Directly [message #269988 is a reply to message #269982] Sun, 05 April 2009 07:29 Go to previous messageGo to next message
Adithya,
Have you investigated how the IDE support File->Open File.. action
works? That would seem to support what you want directly. I believe it
uses IURIEditorInput or IStorageEditorInput...
adithya wrote:
> file system..and i want to give provision for the user to select the
> file dynamically and work on it..
> Adithya.
Re: Working on a File from the File System Directly [message #270311 is a reply to message #269988] Wed, 15 April 2009 09:49 Go to previous messageGo to next message
Ed Merks wrote:
> Adithya,
Actually i have created a perspective which is containing user defined
views..and i have disabled the 'editorArea'..so i am not using the
workbench editor..but the views requires a file as i mentioned
earlier..and i would like to know how does IEditorInput works,because i
couldn't get any relevant information..
How do i get the file name through ' IEditorInput ' interface ?
> adithya wrote:
>> Hi,
>> Adithya.
Re: Working on a File from the File System Directly [message #270318 is a reply to message #270311] Wed, 15 April 2009 11:24 Go to previous messageGo to next message
Adithya,
Typically you'll need to do instance of tests. You've looked at the
class hierarchy rooted at that type?
adithya wrote:
> Ed Merks wrote:
>> Adithya,
>> it uses IURIEditorInput or IStorageEditorInput...
> i couldn't get any relevant information..
>> adithya wrote:
>>> Hi,
>>> string, located in the file system..
>>> Adithya.
Re: Working on a File from the File System Directly [message #270320 is a reply to message #270318] Wed, 15 April 2009 11:33 Go to previous messageGo to next message
Ed Merks wrote:
> Adithya,
No.How do i look at it??
What type of instance tests do you recommend?How does one carry it out?
> adithya wrote:
>> Ed Merks wrote:
>>> Adithya,
>>> adithya wrote:
>>>> Hi,
>>>> Adithya.
Re: Working on a File from the File System Directly [message #270326 is a reply to message #270320] Wed, 15 April 2009 14:49 Go to previous messageGo to next message
Adithya,
You really need to read some documentation about what JDT can all do for
you!
adithya wrote:
> Ed Merks wrote:
>> Adithya,
>> adithya wrote:
>>> Ed Merks wrote:
>>>> Adithya,
>>>> believe it uses IURIEditorInput or IStorageEditorInput...
>>> defined views..and i have disabled the 'editorArea'..so i am not
>>> using the workbench editor..but the views requires a file as i
>>> mentioned earlier..and i would like to know how does IEditorInput
>>> works,because i couldn't get any relevant information..
>>>> adithya wrote:
>>>>> Hi,
>>>>> the contents of it graphically.
>>>>> their file system..and i want to give provision for the user to
>>>>> select the file dynamically and work on it..
>>>>> Adithya.
Re: Working on a File from the File System Directly [message #270342 is a reply to message #270326] Thu, 16 April 2009 03:46 Go to previous messageGo to next message
Ed Merks wrote:
> Adithya,
> you!
Could you please suggest as to how do i proceed?I mean i couldn't get as
to how to give a file as an input to a perspective's view?(Both
perspective and view are user defined)..
Please.
> adithya wrote:
>> Ed Merks wrote:
>>> Adithya,
>>> adithya wrote:
>>>> Ed Merks wrote:
>>>>> Adithya,
>>>>> adithya wrote:
>>>>>> Hi,
>>>>>> Adithya.
Re: Working on a File from the File System Directly [message #270352 is a reply to message #270342] Thu, 16 April 2009 06:56 Go to previous messageGo to next message
Adithya,
I'd take the approach of debugging an editor that's opened from
File->Open File... to see what kind of input in creates and how.
adithya wrote:
> Ed Merks wrote:
>> Adithya,
>> for you!
> as to how to give a file as an input to a perspective's view?(Both
> Please.
>> adithya wrote:
>>> Ed Merks wrote:
>>>> Adithya,
>>>> the class hierarchy rooted at that type?
>>>> adithya wrote:
>>>>> Ed Merks wrote:
>>>>>> Adithya,
>>>>>> action works? That would seem to support what you want
>>>>>> directly. I believe it uses IURIEditorInput or
>>>>>> adithya wrote:
>>>>>>> Hi,
>>>>>>> Adithya.
Re: Working on a File from the File System Directly [message #270354 is a reply to message #270352] Thu, 16 April 2009 08:31 Go to previous message
Ed Merks wrote:
> Adithya,
Or take a look at org.eclipse.core.filebuffers plug-in.
Dani
> adithya wrote:
>> Ed Merks wrote:
>>> Adithya,
>>> for you!
>> Please.
>>> adithya wrote:
>>>> Ed Merks wrote:
>>>>> Adithya,
>>>> out?
>>>>> adithya wrote:
>>>>>> Ed Merks wrote:
>>>>>>> Adithya,
>>>>>>> adithya wrote:
>>>>>>>> Hi,
>>>>>>>> show the contents of it graphically.
>>>>>>>> Adithya.
Previous Topic:menus: visibleWhen=hasActiveHandler?
Next Topic:How to debug a share libray by eclipse CDT
Current Time: Sun Jul 20 03:10:19 EDT 2025
Powered by FUDForum. Page generated in 0.09528 seconds
