Home » Eclipse Projects » Eclipse Platform » Stuck in HelloWorld tutorial
Stuck in HelloWorld tutorial [message #270239] Sun, 05 September 2004 20:22 Go to next message
Originally posted by: Karl.somewhere.com
I'm trying to complete the HelloWorld tutorial in eclipse, but I'm stuck
at the part where I'm supposed to put the main method in.
The tutorial window mentions adding the example code "found in the help
topic associated with this step".
How do I find this help topic? The help menu only has general help, and
doesn't show any code for this step. The only button available is the one
that I press when I've finished.
Re: Stuck in HelloWorld tutorial [message #270241 is a reply to message #270239] Sun, 05 September 2004 20:43 Go to previous messageGo to next message
Update: I think the help topic is supposed to be the little question mark
beside the text in the tutorial window, but when I click on it nothing
happens =(
Re: Stuck in HelloWorld tutorial [message #270315 is a reply to message #270239] Mon, 06 September 2004 14:07 Go to previous messageGo to next message
To which eclipse version do you refere?
Under 3.0, the tutorial worked fine for me.
I've just reviewed (eclipse3.0: Menue / Help / Cheat Sheets / Hello,
World Application)
Please try to identify the tutorial you are using.
eclipse.alt.project - Create a dedicated project newsgroup
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=73282>
< https://bugs.eclipse.org/bugs/votes.cgi?action=show_user& ;bug_id=73282>
http://lazaridis.com
Re: Stuck in HelloWorld tutorial [message #271300 is a reply to message #270315] Tue, 14 September 2004 15:53 Go to previous message
Assuming its the SWT standalone app tutorialm you can click the little
question mark icon to the right of the "Edit the main method" heading in
the tutorial cheat sheet to open the related help topic. Once that
opens you can click the "show in table of contents" icon to see where it
actually lives in the Help system if you'd like.
Steve
> World Application)
>> one
Previous Topic:WebDAV/FTP Plugin: Can't import or browse server
Next Topic:Is Active Help available only when the help system runs in integrated mode?
Current Time: Sun Jul 20 09:44:29 EDT 2025
Powered by FUDForum. Page generated in 0.05988 seconds
