Home » Eclipse Projects » Eclipse Platform » RCP branding problem
RCP branding problem [message #268476] Tue, 24 August 2004 14:53 Go to next message
Originally posted by: nomelody.gmx.net
Hi I am developing an RCP application with Eclipse 3.0 and I am having
trouble with the branding. I have added the following to my plugin.xml
file to change some things like icons/about text... however it does nothing
<extension id="myproduct" point="org.eclipse.core.runtime.products">
<product name="My RPC Application"
application="com.steve.RcpApplication">
<property name="appName" value="My RPC Application"/>
<property name="windowImages" value="icons/product.gif"/>
<property name="aboutText" value="About My RPC Application"/>
<property name="aboutImage" value="icons/product.gif"/>
</product>
</extension>
where "com.steve.RcpApplication" implements IPlatformRunnable. can anybody
point me in the right direction please. I am developing it as an plugin
and not a feature but it shouldnt matter if I add to the
"org.eclipse.core.runtime.products" extension, right? Cheers for any help.
Steve
Re: RCP branding problem [message #268506 is a reply to message #268476] Tue, 24 August 2004 22:46 Go to previous messageGo to next message
Originally posted by: manahan.NOSPAM.ca.ibm.com
Did you run eclipse with either -Declipse.product=<pluginid>.myproduct
or set eclipse.product in the configuration/config.ini file?
Peter
> </product>
> </extension>
> Steve
Re: RCP branding problem [message #268596 is a reply to message #268506] Wed, 25 August 2004 05:58 Go to previous messageGo to next message
Thanks Peter, thats the solution allright, I just needed to set up the
config.ini file correctly, cheers :)
Steve
> Peter
> > </product>
> > </extension>
> > Steve
Re: RCP branding problem [message #268628 is a reply to message #268506] Wed, 25 August 2004 07:16 Go to previous messageGo to next message
> Peter
Btw.: Do you know whether it is possible to envoke the splash screen of
an RCP by starting it via the Eclipse run configurator?
I do get the splash screen in my exported product (where the
osgi.splashPath is correctly set), but currently I don't know how to
get the same effect in the program started by Eclipse itself.
Thanks in advance,
Daniel Krügler
Re: RCP branding problem [message #268643 is a reply to message #268628] Wed, 25 August 2004 08:38 Go to previous messageGo to next message
I tryed setting -Dosgi.splashPath=platform:/base/plugins/<mypluginid> in
the run configurator but no joy. If i get it working Ill mail you.
Steve
> > Peter
> Thanks in advance,
> Daniel Krügler
Re: RCP branding problem [message #268751 is a reply to message #268476] Wed, 25 August 2004 21:22 Go to previous messageGo to next message
Originally posted by: pascal.ibm.canada
You can find info about branding a product here:
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-core-home/docs/branding/BrandingYourApplication.html
PaScaL
> </product>
> </extension>
> Steve
Re: RCP branding problem [message #268782 is a reply to message #268751] Thu, 26 August 2004 04:29 Go to previous messageGo to next message
Hello Pascal Rapicault,
Thanks for that nicely written document!
One question remains: In the section "Replacing the splash screen" it says
The splash screen to be displayed is controlled by system properties
that can either be passed as vm arguments or added to the config.ini
file that we modified previously. The two properties are:
* osgi.splashLocation: full path to the splash screen in the file
system. For example
c:/eclipse/plugins/org.eclipse.ui.examples.rcp.browser/splas h.bmp;
* osgi.splashPath: comma separated list of URL that will be searched for
the splash screen. Only "file:" and "platform:" URLs are supported. For
example platform:/base/plugins/org.eclipse.ui.examples.rcp.browser/. The
entries will be searched until a file called splash.bmp is found.
My product branding concerning the splash screen does work in the
deployed version, but not the version started by the Eclipse run
configurator (where the configuration is set to "Run as product").
Lets say the plugin providing the product extension is named
com.example.ui, I added the the VM argument
-Dosgi.splashPath=platform:/base/plugins/com.example.ui
where the splash.bmp is located in my workspace/com.example.ui
directory, but it doesn't work (Btw: I also tried
-Dosgi.splashPath=platform:/base/plugins/com.example.ui/
Please note that the remaining product features like windowImages and
in the **deployed** version (via its config.ini entry) **does** work.
Is that a bug or what is my error here??
Thanks in advance,
Daniel Krügler
Re: RCP branding problem [message #268804 is a reply to message #268782] Thu, 26 August 2004 08:08 Go to previous message
The osgi.splashPath does not work in selfhost (because Main which does
not know a lot, only looks for the plugins in the plugin folder).
It could be good if you opened a bug report against platform runtime.
PaScaL
> system. For example
> Thanks in advance,
> Daniel Krügler
Previous Topic:[OT] j9 VM
Next Topic:Plugin discover its own version
Current Time: Sun Jul 20 10:32:18 EDT 2025
Powered by FUDForum. Page generated in 0.24628 seconds
