Home » Newcomers » Newcomers » Cannot build CDT project
Cannot build CDT project [message #268189] Wed, 28 January 2009 15:07 Go to next message
Originally posted by: jamescobban.sympatico.ca
I just migrated to eclipse-cpp-ganymede-SR1-win32 and attempted to
reconfigure to use MinGW GCC for the compiler using the procedure
described by Fred Lackey's wiki. When I try to build an existing
project I get the following output:
make all
Building file: ../Address.cpp
Invoking: GCC C++ Compiler
g++ -O0 -g3 -Wall -c -fmessage-length=0 -MMD -MP -MF"Address.d"
-MT"Address.d" -o"Address.o" "../Address.cpp"
This application has requested the Runtime to terminate it in an unusual
way.
Please contact the application's support team for more information.
make: *** [Address.o] Error 3
The Project Properties specify PATH="C:\msys\1.0\bin;C:/MinGW/bin;
C:/Program Files/Java/jre1.6.0_07/bin/client;
C:/Program Files/Java/jre1.6.0_07/bin;
C:\Program Files\Apache Software Foundation\Apache2.2\PHP\;
C:\WINDOWS\system32;
C:\WINDOWS;
C:\WINDOWS\System32\Wbem;
C:\MinGW\bin;C:\Cygwin\bin;
C:\Program Files\MySQL\MySQL Server 5.0\bin;
C:\Program Files\QuickTime\QTSystem\;
C:\Program Files\CA\PPRT\bin"
The Windows environment variables specify
Path="C:\Program Files\Apache Software Foundation\Apache2.2\PHP\;
%SystemRoot%\system32;
%SystemRoot%;
%SystemRoot%\System32\Wbem;
C:\msys\1.0\bin;C:\MinGW\bin;
C:\Cygwin\bin;
If I invoke make directly from msys it appears to work in that the
output is different:
make
In file included from ../Address.h:17,
from ../Address.cpp:14:
.../Tag.h:751: error: 'time_t' in namespace 'std' does not name a type
.../Tag.h:752: error: 'tm' in namespace 'std' does not name a type
.../Tag.h:753: error: 'time_t' in namespace 'std' does not name a type
.../Tag.h:788: error: function definition does not declare parameters
.../Tag.h:799: error: function definition does not declare parameters
make: *** [Address.o] Error 1
Any ideas of what I can do to get this to work?
Re: Cannot build CDT project [message #268199 is a reply to message #268189] Thu, 29 January 2009 03:11 Go to previous messageGo to next message
Originally posted by: subs._nospam_consertum.com
It appears that the compiler is probably crashing. Have you tried do the
same thing from the command line?
> make all
> way.
> C:\WINDOWS;
> %SystemRoot%;
> C:\Cygwin\bin;
> make
Derek
Re: Cannot build CDT project [message #268205 is a reply to message #268199] Thu, 29 January 2009 10:14 Go to previous messageGo to next message
I showed the output from the command line in the original posting:
>> make
Re: Cannot build CDT project [message #268209 is a reply to message #268205] Thu, 29 January 2009 14:16 Go to previous message
Originally posted by: eclipse-news.rizzoweb.com
You might get more response posting this to the eclipse.tools.cdt newsgroup.
Eric
On 1/29/2009 10:14 AM, James Cobban wrote:
>> the same thing from the command line?
>>> make
Previous Topic:C/C++ Perspective missing ...
Next Topic:Creating "VIEWS" in Eclipse
Current Time: Sat Jul 19 19:16:08 EDT 2025
Powered by FUDForum. Page generated in 0.08976 seconds
