Home » Eclipse Projects » Eclipse Platform » markerAnnotationSpecification problems: Highlights not showing
markerAnnotationSpecification problems: Highlights not showing [message #265593] Thu, 05 August 2004 19:47 Go to next message
In my plugin.xml file I define both a
org.eclipse.ui.editors.annotationTypes structure and a
org.eclipse.ui.editors.markerAnnotationSpecification specification.
What I want to do is apply these annotations (specifically, highlighting
the text a color; similar to what the google toolbar "highlight" feature
does with text on web-pages) to a marker. My markers show perfectly in the
editors, but the highlighting doesn't.
Here's how I create it:
IMarker marker;
MarkerAnnotation annotation;
marker = file.createMarker("edu.ucsd.aspectbrowser.aspectmarker");
marker.setAttributes(map);
annotation = new MarkerAnnotation("edu.ucsd.aspectbrowser.highlight",
marker);
annotation.update();
Has someone else run into problems with this? Is there a short code sample
that shows how to perform text highlighting via markers?
Macneil
Re: markerAnnotationSpecification problems: Highlights not showing [message #265720 is a reply to message #265593] Fri, 06 August 2004 09:02 Go to previous messageGo to next message
Does your annotation type show up in Window > Preferences > Editors >
Annotations? If so, is highlighted in text checked? I can only say more
if I see your concrete extension.
>IMarker marker;
That's OK, but the following code is not needed because the text-based
editors automatically convert markers into annotations if the
annotationTypes extension point is correctly provided.
Dani
>marker);
>Thanks,
>Macneil
Re: markerAnnotationSpecification problems: Highlights not showing [message #265826 is a reply to message #265720] Fri, 06 August 2004 17:00 Go to previous messageGo to next message
Here's what I have:
<extension point="org.eclipse.core.resources.markers"
id="aspectmarker"
name="Aspect Marker">
<persistent value="false"/>
</extension>
<extension point="org.eclipse.ui.editors.annotationTypes">
<type name="edu.ucsd.aspectbrowser.highlight"/>
</extension>
<extension point="org.eclipse.ui.editors.markerAnnotationSpecification ">
<specification
colorPreferenceValue="0,255,255"
annotationType="edu.ucsd.aspectbrowser.highlight"
overviewRulerPreferenceValue="false"
presentationLayer="3"/>
</extension>
And, no, the annotation doesn't show up in the preferences screen. What am
I doing wrong?
Macneil
> >IMarker marker;
> Dani
> >marker);
> >Thanks,
> >Macneil
Re: markerAnnotationSpecification problems: Highlights not showing [message #266616 is a reply to message #265826] Wed, 11 August 2004 17:45 Go to previous message
I found the solution:
id="aspectmarker"
name="aspectmarker">
<super type="org.eclipse.core.resources.textmarker"/>
</extension>
<type name="edu.ucsd.aspectbrowser.highlightannotation"
markerType="edu.ucsd.aspectbrowser.aspectmarker"/>
</extension>
<specification
annotationType="edu.ucsd.aspectbrowser.highlightannotation"
verticalRulerPreferenceKey="highlight.rulers.vertical"
textPreferenceKey="highlight.text"
colorPreferenceKey="highlight.color"
highlightPreferenceKey="highlight.background"
textPreferenceValue="false"
textStylePreferenceValue="NONE"
overviewRulerPreferenceKey="highlight.rulers.overview"
presentationLayer="4"
highlightPreferenceValue="true"
label="Aspect Browser"
colorPreferenceValue="253,255,157"
verticalRulerPreferenceValue="true"
overviewRulerPreferenceValue="true"
textStylePreferenceKey="highlight.text.style"/>
</extension>
Thanks everyone!
-Macneil
Previous Topic:Problems with selection provider.
Next Topic:Re: Xerces with Eclipse 3.0
Current Time: Sat Jul 19 05:38:28 EDT 2025
Powered by FUDForum. Page generated in 0.05213 seconds
