Home » Archived » BIRT » Dynamic Connection Profiles
Dynamic Connection Profiles [message #264671] Wed, 16 January 2008 12:29 Go to next message
Originally posted by: tom.eiswind.de
HI I just had a look at the dynamic profiles. But I seem to go all
wrong. When I export a datasource profile and change the connection
properties in the file the data source explorer recognizes it but the
data source based on it isnt changed.
any hints ?
Re: Dynamic Connection Profiles [message #264678 is a reply to message #264671] Wed, 16 January 2008 13:38 Go to previous messageGo to next message
Hi Thomas,
What version of BIRT are you using? In my simple testing with BIRT
2.2.0, mine worked. I exported my connection profile to a file (not
encrytped), and then used that connection profile for my BIRT data
source. When I change the database URL in the text file, the next run
of the report uses the new data. I did not try to change anything else,
like the driver, username or password.
Virgil
http://www.birt-exchange.com
> any hints ?
Re: Dynamic Connection Profiles [message #264682 is a reply to message #264671] Wed, 16 January 2008 14:00 Go to previous messageGo to next message
Ok got it working now. But the absolute Path to the profile store sucks,
how will I deploy that to a production machine ?
Is there a way to give a relative path ?
I have spring starting jetty starting birt runtime. An http URL would be
great.
> any hints ?
Re: Dynamic Connection Profiles [message #264700 is a reply to message #264682] Wed, 16 January 2008 15:07 Go to previous messageGo to next message
Hi again Thomas,
I could not get a URL to work, however, you can have more control in the
property binding tab. There you can control the location of the
connection profile with an expression. I created a simple example to
try this out that uses a parameter to control the location of the
connection profile. I uploaded it to
http://www.birt-exchange.com/modules/wfdownloads/singlefile. php?cid=2&lid=251
I put a simple readme.txt in there with a few steps to use the example.
Let me know if a step is missing since I haven't tested it on another
machine.
Virgil
> great.
>> any hints ?
Re: Dynamic Connection Profiles [message #264738 is a reply to message #264700] Thu, 17 January 2008 02:23 Go to previous message
I filed an enhancement request on this.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=215623
Previous Topic:Getting a chart's preferred size
Next Topic:Adding values series to chart using scripting
Current Time: Sat Jul 19 13:56:32 EDT 2025
Powered by FUDForum. Page generated in 0.04792 seconds
