Home » Eclipse Projects » Eclipse Platform » RCP - move "configuration" folder to some user-specific path?
RCP - move "configuration" folder to some user-specific path? [message #263181] Thu, 22 July 2004 10:19 Go to next message
is there a way to have all variable ("state") information stored in a
user-specific path instead of below the RCP installation directory?
I'd like to deploy an RCP application to a Citrix MetaFrame server
farm, and this would require that multiple concurrent sessions use the
same installation path - I'd like to have predictable, user-specific
results though. I hope I'm not askiing to be spoon-fed here, I'd be
grateful for a pointer...
-- Jan
Re: RCP - move "configuration" folder to some user-specific path? [message #263221 is a reply to message #263181] Thu, 22 July 2004 11:19 Go to previous messageGo to next message
hi there
in eclipse 3.0 the preferences framework has changed quite a bit from 2.1
a good reading is this:
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-core-home/documents/user_settings/faq.html
when you want to specify the location of your preferences (other than the
default ones INSTANCE, CONFIGURATION, PROJECT, DEFAULT etc) you would have
to implement the IScopeContext with its getLocation() methode. Or extend
the AbstractScope.
greets moritz
Re: RCP - move "configuration" folder to some user-specific path? [message #263435 is a reply to message #263221] Fri, 23 July 2004 04:44 Go to previous messageGo to next message
On Thu, 22 Jul 2004 15:19:51 +0000 (UTC), moritzpost@gmx.de (Moritz
>the AbstractScope.
I had already read that, but what I was trying to ask was whether it
was possible to change not the logical hierarchy (ie. scope) in which
to store the preferences, but to store them in a different filesystem
path for each user (actually a Windows user profile). From my
understanding, scopes won't help me with that, or will they?
-- Jan
Re: RCP - move "configuration" folder to some user-specific path? [message #263438 is a reply to message #263221] Fri, 23 July 2004 04:46 Go to previous message
Post) wrote:
>hi there
I now see the light. Don't bother responding to my previous follow-up.
-- Jan
Previous Topic:Active WorkbenchWindow
Next Topic:Register at SelectionService
Current Time: Sat Jul 19 08:50:26 EDT 2025
Powered by FUDForum. Page generated in 0.33516 seconds
