Home » Archived » BIRT » An issue in preview tag
An issue in preview tag [message #259696] Fri, 26 October 2007 13:58 Go to next message
I tried to use preview tag, But I faced an issue as I added it in my code,
in IE (not Firefox).
IE shows alert "The page can not be open". As I tracked it down (for few
hours), I found out that tag creates a form internally dynamically & as I
put the tag inside a div, in IE 7, it won't work. Following is a sample to
reproduce the scenario:
<div>
<script type="text/javascript">
function loadViewersample_chart(){
var bodyObj = document.body;
var formObj = document.createElement( "FORM" );
bodyObj.appendChild( formObj );
formObj.action =
" http://localhost:8080/birt//preview?__format=html&__repo rt=sample-chart.rptdesign&__masterpage=true";
formObj.method = "post";
formObj.target = "sample_chart";
formObj.submit( );
</script>
<iframe name="sample_chart"></iframe>
<script type="text/javascript">loadViewersample_chart();</script>
</div>
Does anybody know a solution for that?
Farid
Re: An issue in preview tag [message #259773 is a reply to message #259696] Mon, 29 October 2007 10:30 Go to previous messageGo to next message
Originally posted by: jasonweathersby.alltel.net
Farid,
Do you have the preview tag nested in another div? This is a known
issue with ie 7. You can try setting the reportContainer attribute tag
to div.
Jason
Farid wrote:
> <div>
> formObj.action =
> formObj.submit( );
> </script>
> </div>
> Thanks
> Farid
Re: An issue in preview tag [message #260099 is a reply to message #259773] Wed, 31 October 2007 14:48 Go to previous messageGo to next message
Jason,
I tried your solution, but I face another issue. I have the birt running as
a seperate application. The tag in my code looks like this:
<birt:report reportContainer="div" id="sample_chart" baseURL="/birt"
isHostPage="false" showParameterPage="false" height="600" width="800"
reportDesign="${param.reportName}"></birt:report>
But it shows an error:
The report file :
C:\projects\eclipseworkspace\.metadata\.plugins\org.eclipse. wst.server.core\tmp2\webapps\selfadmin\clientSale.rptdesign
does not exist or contains errors.
As I use the tag without reportContainer attribute (in Firefox) it works
fine.
Farid
"Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
news:fg4qkc$45n$2@build.eclipse.org...
> Farid,
> Do you have the preview tag nested in another div? This is a known issue
> with ie 7. You can try setting the reportContainer attribute tag to div.
> Jason
> Farid wrote:
>> Hi,
>> code, in IE (not Firefox).
>> to reproduce the scenario:
>> <div>
>> formObj.action =
>> formObj.submit( );
>> </script>
>> </div>
>> Thanks
>> Farid
Re: An issue in preview tag [message #260197 is a reply to message #260099] Thu, 01 November 2007 09:50 Go to previous messageGo to next message
Farid,
If you hard code the reportDesign, does this work?
Also reportDesign if relative will be in relation to the /birt context.
Jason
Farid wrote:
> Jason,
> The report file :
> fine.
> Thanks
> Farid
>> Farid,
>> Jason
>> Farid wrote:
>>> Hi,
>>> <div>
>>> formObj.action =
>>> formObj.submit( );
>>> </script>
>>> </div>
>>> Thanks
>>> Farid
Re: An issue in preview tag [message #260641 is a reply to message #260197] Mon, 05 November 2007 11:32 Go to previous messageGo to next message
The result won't be different. It tries to find the report in local context.
news:fgcles$mm8$1@build.eclipse.org...
> Farid,
> Jason
> Farid wrote:
>> Jason,
>> as a seperate application. The tag in my code looks like this:
>> The report file :
>> fine.
>> Thanks
>> Farid
>>> Farid,
>>> to div.
>>> Jason
>>> Farid wrote:
>>>> Hi,
>>>> few hours), I found out that tag creates a form internally dynamically
>>>> & as I put the tag inside a div, in IE 7, it won't work. Following is a
>>>> sample to reproduce the scenario:
>>>> <div>
>>>> formObj.action =
>>>> formObj.submit( );
>>>> </script>
>>>> </div>
>>>> Thanks
>>>> Farid
Re: An issue in preview tag [message #260683 is a reply to message #260641] Mon, 05 November 2007 13:28 Go to previous message
Farid,
Is this jsp page in the /birt context or another?
Also if you set
reportDesign="c:/temp/clientSale.rptdesign" does it find the report?
Lastly can you set logging in the /birt context by modifying its web.xml
and setting the logging directory and post the log?
Jason
>> Farid,
>> Jason
>> Farid wrote:
>>> Jason,
>>> The report file :
>>> fine.
>>> Thanks
>>> Farid
>>>> Farid,
>>>> to div.
>>>> Jason
>>>> Farid wrote:
>>>>> Hi,
>>>>> <div>
>>>>> formObj.action =
>>>>> formObj.submit( );
>>>>> </script>
>>>>> </div>
>>>>> Thanks
>>>>> Farid
Previous Topic:BIRT 2.2.1 and WAS CE 2.0 - can't start BIRT.
Next Topic:Charting: Making gaps in line chart from groups (instead of nulls)
Current Time: Sat Jul 19 11:38:58 EDT 2025
Powered by FUDForum. Page generated in 0.04074 seconds
