Problem with IJavaSearchScope [message #258523] |
Fri, 06 February 2009 06:54  |
hello,
i am building an application that finds pattern for Integer() wrapper
class, means occurance of Integer() in a java file. for that i find
eclipse.jdt.core.search and with that i build a program but it throws
ExceptionInInitializerError
I am not getting why this error has occured, please help me to solve my
problem.....
thnx in advance...
my source code is as follows:
import org.eclipse.jdt.core.IClassFile;
import org.eclipse.jdt.core.ICompilationUnit;
import org.eclipse.jdt.core.IJavaElement;
import org.eclipse.jdt.core.IJavaProject;
import org.eclipse.jdt.core.IPackageFragment;
import org.eclipse.jdt.core.IPackageFragmentRoot;
import org.eclipse.jdt.core.search.IJavaSearchConstants;
import org.eclipse.jdt.core.search.IJavaSearchScope;
import org.eclipse.jdt.core.search.SearchEngine;
import org.eclipse.jdt.core.search.SearchMatch;
import org.eclipse.jdt.core.search.SearchParticipant;
import org.eclipse.jdt.core.search.SearchPattern;
import org.eclipse.jdt.core.search.SearchRequestor;
import org.eclipse.core.*;
import org.eclipse.core.resources.*;
import org.eclipse.core.runtime.CoreException;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.jdt.core.util.*;
import java.io.IOException;
import java.io.InputStream;
import java.lang.*;
import java.util.ArrayList;
import java.util.Iterator;
import java.util.StringTokenizer;
import org.osgi.*;
import org.eclipse.jface.viewers.ISelection;
import org.eclipse.jface.viewers.IStructuredSelection;
public class test {
IPackageFragment pkg ;
IJavaSearchScope scope;
public void parser() throws IOException {
// TODO Auto-generated method stub
try {
System.out.println("in method..");
SearchPattern pattern = SearchPattern.createPattern(
"Integer*",
IJavaSearchConstants.METHOD,
IJavaSearchConstants.DECLARATIONS,
SearchPattern.R_PATTERN_MATCH);
scope = SearchEngine.createJavaSearchScope(new IJavaElement[]{this.pkg});
SearchRequestor requestor = new SearchRequestor() {
public void acceptSearchMatch(SearchMatch match) {
System.out.println(match.getElement());
SearchEngine searchEngine= new SearchEngine();
searchEngine.search(pattern, new
SearchParticipant[]{SearchEngine.getDefaultSearchParticipant ()}, scope,
requestor, null);
} catch (CoreException e) {
System.out.println(e.getCause());
catch(NullPointerException ne){
System.out.println(ne.getCause());
catch (ExceptionInInitializerError ee) {
System.out.println(ee.getCause());
Re: Problem with IJavaSearchScope [message #258580 is a reply to message #258523] |
Tue, 10 February 2009 10:42  |
gunjju wrote:
> hello,
> problem.....
> thnx in advance...
> import java.lang.*;
> import org.osgi.*;
> public class test {
> try {
> "Integer*", IJavaSearchConstants.METHOD,
> requestor, null);
It looks like you're running this snippet as a Java application...
If so, could you try to run it as an Eclipse application?
I also doubt that this snippet will address your search need.
The created pattern is about method declarations although that
reading your first paragraph it sounds to me that you wanted
to search either for Integer constructors or class references.
The former would expect the following pattern:
"Integer",
IJavaSearchConstants.CONSTRUCTOR,
IJavaSearchConstants.REFERENCES,
SearchPattern.R_EXACT_MATCH);
The latter would expect the following pattern:
"Integer",
IJavaSearchConstants.CLASS,
FUDForum. Page generated in 0.09447 seconds
