Home » Language IDEs » Java Development Tools (JDT) » [Local variables not available] problem with debugger
[Local variables not available] problem with debugger [message #258265] Mon, 26 January 2009 13:34 Go to next message
I am trying to understand the keySet() method of Map interface by
inspecting the class HashMap. I placed a breakpoint on the keySet() method
of HashMap, but the debugger reports "[Local variables not available]".
Consequently, I could not know how the Set is initialized for the first
time and how it is synchronization with the backing map. I can see the
source code for the respective classes so I guess that should not be the
problem. Can anyone suggest me what should I do so as to remove this
problem?
Mahim Lakhani
Re: [Local variables not available] problem with debugger [message #258269 is a reply to message #258265] Mon, 26 January 2009 14:42 Go to previous messageGo to next message
Originally posted by: eclipse-news.rizzoweb.com
On 1/26/2009 1:34 PM, Mahim Lakhani wrote:
> method of HashMap, but the debugger reports "[Local variables not
> available]". Consequently, I could not know how the Set is initialized
> for the first time and how it is synchronization with the backing map. I
> can see the source code for the respective classes so I guess that
> should not be the problem. Can anyone suggest me what should I do so as
> to remove this problem?
The problem is that the core Java library (rt.jar) does not come
compiled with debugging info enabled, so at runtime the information is
limited.
There has been a long-standing bug report open with Sun to provide a
rt.jar that is compiled with debugging enabled, but I don't know the
current status of that issue.
Eric
Re: [Local variables not available] problem with debugger [message #258303 is a reply to message #258269] Tue, 27 January 2009 02:02 Go to previous message
Thanks Eric. I had no idea about that.
Previous Topic:Test plugins with Java projects
Next Topic:Problems with Classpaths?
Current Time: Sat Jul 19 12:29:05 EDT 2025
Powered by FUDForum. Page generated in 0.03250 seconds
