Home » Archived » BIRT » XLS Emitter Configuration
XLS Emitter Configuration [message #256444] Thu, 27 September 2007 09:27 Go to next message
Originally posted by: amanita.mail.ru
I have to determine fixed column width in Excel for report exported from
BIRT. My report have over 30 columns and XLS Emitter makes the columns
"one-character-width". This is unreadable. I have found this code:
// setup XLS emitter configuration
Map xlsConfig = new HashMap( );
// Check out constants in XlsEmitterConfig.java for more configuration
detail.
xlsConfig.put( "fixed_column_width", new Integer( 150 ) ); //$NON-NLS-1$
// Associate the configuration with the XLS output format.
config.setEmitterConfiguration( XLS_FORMAT, xlsConfig );
But it doesn't work for me, there are no changes in Excel file. I have
either error nor the columns have the fixed width. This code seems to be
ignored.
Can someone help me to fix this problem. Thank you!
Sam
Re: XLS Emitter Configuration [message #256647 is a reply to message #256444] Mon, 01 October 2007 05:05 Go to previous messageGo to next message
I do not need a complete solution. I would appreciate if you just give me
a hint if there is a possibility to configurate the emitter.
Thank you very much,
Sam
Re: XLS Emitter Configuration [message #256682 is a reply to message #256444] Mon, 01 October 2007 15:39 Go to previous messageGo to next message
Sam,
Are you sure you are looking at the same XLS emitter? The code you have
posted seems like for the XLS emitter from tribix which is not same as the
one that comes built-in with the birt engine. I think that's why the code
does not have any effect on the final output. If you want to use tribix XLS
emitter, you can download it and use it. But make sure that the birt
internal xls emitter should be removed before using tribix one, because it
confuses the report engine and no output is generated.
Bidyut
"Sam" <amanita@mail.ru> wrote in message
news:15cf5c9fdbe8b7c25b597192f69df14d$1@www.eclipse.org...
> Hello,
> detail.
> ignored.
> Sam
Re: XLS Emitter Configuration [message #256707 is a reply to message #256682] Tue, 02 October 2007 03:59 Go to previous message
Bidyut, thank you very much. I did not know there are 2 emitters: i have
just managed to install tribix emitter and it works according to my needs.
Sam
Previous Topic:Taglib starts and shuts down engine every time
Next Topic:Problems with Postscript fonts
Current Time: Sun Jul 20 09:32:13 EDT 2025
Powered by FUDForum. Page generated in 0.26683 seconds
