Home » Modeling » OCL » ocl contains operations over strings
ocl contains operations over strings [message #25556] Tue, 29 May 2007 11:12 Go to next message
Originally posted by: angel.calvo.centic.es
Hello!
Is there any operation in OCL which returns if a string contains spaces?
Thanks.
Re: ocl contains operations over strings [message #25596 is a reply to message #25556] Tue, 29 May 2007 11:32 Go to previous messageGo to next message
Hi, Angel,
Nope. But, you can do this:
Sequence{1..s.size()}->exists(i | s.substring(i, i) = ' ')
to determine whether a string s contains spaces.
You can even use OCL to define this as an additional operation in your
environment:
context String
def: hasSpace : boolean =
Sequence{1..self.size()}->exists(i | self.substring(i, i) = ' ')
HTH,
Christian
Angel Luis Calvo Ortega wrote:
> Hello!
> Thanks.
Re: ocl contains operations over strings [message #25801 is a reply to message #25596] Tue, 29 May 2007 13:16 Go to previous messageGo to next message
Thanks a lot Christian!
It's worked perferctly.
Christian W. Damus escribió:
> Hi, Angel,
> environment:
> context String
> HTH,
> Christian
>> Hello!
>> Thanks.
Re: ocl contains operations over strings [message #923023 is a reply to message #25556] Tue, 25 September 2012 10:44 Go to previous messageGo to next message
Hi friends,
leveraging the post I would like to know if have way to know if a string has a substring.
For example to know if string: 'return 123+996*oldVar' has substring 'return'
If you can help me, I thank you.
I already tried formulate the expression but I had no success.
Thank you for the help and I'm sorry about the english.
Pablo.
Re: ocl contains operations over strings [message #923093 is a reply to message #923023] Tue, 25 September 2012 11:39 Go to previous message
The OCL string library has been gradually improving.
The Juno release of Eclipse OCL has further String functions such as
regex. See the Help documentation.
Ed Willink
On 25/09/2012 15:44, Pablo Silva wrote:
> Hi friends,
> 'return'
> Pablo.
Previous Topic:Simplify OCL query
Next Topic:OCl variable of type EEList
Current Time: Sun Jul 20 11:47:03 EDT 2025
Powered by FUDForum. Page generated in 0.03598 seconds
