Home » Eclipse Projects » Eclipse Platform » Eclipse hangs in Fedora Core 2
Eclipse hangs in Fedora Core 2 [message #255419] Thu, 24 June 2004 14:32 Go to next message
Originally posted by: warren.roberts.name
I've just tried to run eclipse-SDK-3.0RC1-linux-gtk.zip on Fedora core 2
but it hangs my machine and disables my keyboard. I passed in the
following vmargs
-vmargs -Xms64m -Xmx512m
I'm using j2sdk-1_4_2_04-linux-i586.rpm for my jvm.
I reinstalled and tried this twice with the same result. Has anyone else
out there had a similar problem (or success with core 2)?
Thanx
Warren
Re: Eclipse hangs in Fedora Core 2 [message #255434 is a reply to message #255419] Thu, 24 June 2004 16:38 Go to previous messageGo to next message
Success (3.0RC* builds, Fedora Core2, j2sdk-1_4_2_04
Konrad
"Warren Roberts" <warren@roberts.name> wrote in message
news:cbf6nq$v7p$1@eclipse.org...
> following vmargs
> Thanx
> Warren
Re: Eclipse hangs in Fedora Core 2 [message #255442 is a reply to message #255434] Thu, 24 June 2004 16:54 Go to previous messageGo to next message
Hmmm so you built it on Core 2. I was just trying to use the binary
distro.
> Konrad
> > following vmargs
> > Thanx
> > Warren
Re: Eclipse hangs in Fedora Core 2 [message #255445 is a reply to message #255442] Thu, 24 June 2004 17:33 Go to previous messageGo to next message
No, I was downloading binary builds from eclipse site. Worked out of the
box.
Konrad
news:cbff1s$eeo$1@eclipse.org...
> distro.
> > Konrad
2
> > > following vmargs
else
> > > Thanx
> > > Warren
Re: Eclipse hangs in Fedora Core 2 [message #255463 is a reply to message #255445] Thu, 24 June 2004 17:59 Go to previous messageGo to next message
It works for me as long as I don't pass in -vmargs. Unfortunately I need
a pretty large memory footprint. I wonder if it has to do with the change
in stack sice in the 2.6 kernel?
Warren
> box.
> Konrad
> > distro.
> > > Konrad
> 2
> > > > following vmargs
> else
> > > > Thanx
> > > > Warren
Re: Eclipse hangs in Fedora Core 2 [message #255509 is a reply to message #255463] Thu, 24 June 2004 22:19 Go to previous messageGo to next message
I have successfully installed and run the 3.0RC2 binaries on Fedora Core 2
with the
1.4.2_04 JDK and set -vmargs -Xmx512m.
news:cbfirf$keo$1@eclipse.org...
> Warren
the
> > box.
> > Konrad
> > > distro.
> > > > Konrad
core
> > 2
> > > > > following vmargs
anyone
> > else
> > > > > Thanx
> > > > > Warren
Re: Eclipse hangs in Fedora Core 2 [message #255733 is a reply to message #255419] Fri, 25 June 2004 15:38 Go to previous message
> following vmargs
This is a known problem with running any java app on the kernel that ships
with fedora core 2 (2.6.5-i686).
For more details on what you can do to fix it, read here:
https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=121902
For me, downgrading my kernel to the i586 version did the trick.
Upgrading to 2.6.6 should also do the trick (Wasn't available when I ran
into the problem).
Matt
Previous Topic:Fast View not being created?
Next Topic:JUnit Plug-in test threading issues
Current Time: Sat Jul 19 19:49:48 EDT 2025
Powered by FUDForum. Page generated in 0.04168 seconds
