Home » Newcomers » Newcomers » How to ignore @Override under 1.4?
How to ignore @Override under 1.4? [message #254274] Fri, 18 April 2008 14:12 Go to next message
Originally posted by: fake.phony_email_address.com
We've got a lot of code that uses @Override tags, and we need it to
compile under JDK 1.4. They cause compile errors. I'd rather not remove
the tags because they're really useful under 1.5.
Is there any way in Eclipse Preferences to temporarily ignore the
@Override tags when compiling under 1.4?
Re: How to ignore @Override under 1.4? [message #254287 is a reply to message #254274] Fri, 18 April 2008 16:46 Go to previous messageGo to next message
Try setting the compiler level to 1.6, but the "generated .class files
compatibility" to 1.4
Wayne
Re: How to ignore @Override under 1.4? [message #254299 is a reply to message #254287] Sat, 19 April 2008 07:25 Go to previous messageGo to next message
--------------090705050708090206010303
Wayne,
I think the .class file compatibility must be greater or equal to the
source compatibility... It would be nice if Java could compile 1.5
level source down to 1.4 compatible byte code...
> Wayne
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Wayne,<br>
<br>
source compatibility...&nbsp; It would be nice if Java could compile 1.5
level source down to 1.4 compatible byte code...<br>
<br>
<br>
Wayne Beaton wrote:
<blockquote cite="mid:1208551584.6093.98.camel@BADWOLF" type="cite">
<pre wrap="">Try setting the compiler level to 1.6, but the "generated .class files
Wayne
</pre>
<blockquote type="cite">
<pre wrap="">We've got a lot of code that uses @Override tags, and we need it to
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------090705050708090206010303--
Re: How to ignore @Override under 1.4? [message #254306 is a reply to message #254299] Sat, 19 April 2008 08:45 Go to previous messageGo to next message
Hi Ed,
It can some if you are using only things compatible with Java-1.4.
See http://dev.eclipse.org/newslists/news.eclipse.tools.jdt/msg2 0212.html
Tom
Ed Merks schrieb:
> Wayne,
>> Wayne
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: How to ignore @Override under 1.4? [message #254312 is a reply to message #254306] Sat, 19 April 2008 11:25 Go to previous messageGo to next message
Tom,
Interesting. I suppose that doesn't mean it tosses generics away if you
use them, which would be an interesting capability...
Tom Schindl wrote:
> Hi Ed,
> Tom
> Ed Merks schrieb:
>> Wayne,
>>> Wayne
>>>> remove the tags because they're really useful under 1.5.
Re: How to ignore @Override under 1.4? [message #254316 is a reply to message #254312] Sat, 19 April 2008 11:34 Go to previous messageGo to next message
Well not at all if I read the document i referenced there appropiately
what the compiler does is simply adding casts inside the byte-code. This
could also be a pointer for our Java-5 discussion on the e4 mailinglist.
Tom
Ed Merks schrieb:
> Tom,
> Tom Schindl wrote:
>> Hi Ed,
>> Tom
>> Ed Merks schrieb:
>>> Wayne,
>>>> Wayne
Re: How to ignore @Override under 1.4? [message #254348 is a reply to message #254299] Sun, 20 April 2008 14:42 Go to previous message
Thanks Ed. I was too lazy to try it myself; however, the properties let
you do this, so I thought it was worth a crack.
Wayne
On Sat, 2008-04-19 at 07:25 -0400, Ed Merks wrote:
> Wayne,
> > Wayne
Previous Topic:Move J2ee interfaces to other package with xdoclet
Next Topic:rse; dstore connector service; using port 0 error
Current Time: Sat Jul 19 06:31:52 EDT 2025
Powered by FUDForum. Page generated in 0.10250 seconds
