Home » Newcomers » Newcomers » Opening an editor
Opening an editor [message #252823] Mon, 31 March 2008 22:57 Go to next message
Originally posted by: daved99.comcast.net
I am missing something here. I need to be able to programmatically open
an editor, but whenever I attempt to use any of the snippets here they
will NOT compile.
Most recently I tried this:
page.openEditor
(new FileEditorInput(modelFile),
workbench.getEditorRegistry().getDefaultEditor(modelFile.get FullPath().toString()).getId());
Eclipse gets all excited about "FileEditorInput". Does NOT recognize this
as a class. I look it up and it is supposed to be in
"org.eclipse.ui.part" which IS imported - still won't find it.
I have the same problem with the IDE.method - Eclipse can't find "IDE".
Same story with IStorageEditorInput.
What am I missing?
Re: Opening an editor [message #252827 is a reply to message #252823] Tue, 01 April 2008 03:31 Go to previous messageGo to next message
> open an editor, but whenever I attempt to use any of the snippets here
> they will NOT compile.
> page.openEditor
> this as a class. I look it up and it is supposed to be in
> What am I missing?
At least you miss org.eclipse.ui.ide in the list of required bundles.
Dani
Re: Opening an editor [message #252993 is a reply to message #252823] Wed, 02 April 2008 18:44 Go to previous messageGo to next message
Hey Dave,
Have you set your plugin to require the org.eclipse.ui plugins that contain
the imported classes?
Check out the Dependencies tab on your Plug-in Manifest editor opened on the
plugin.xml of your plugin.
HTH
Darins
http://runnerwhocodes.blogspot.com
"Dave" <daved99@comcast.net> wrote in message
news:8f606aea2d4ef3581e42e900be5a3421$1@www.eclipse.org...
>I am missing something here. I need to be able to programmatically open an
>editor, but whenever I attempt to use any of the snippets here they will
>NOT compile.
> page.openEditor
> What am I missing?
Re: Opening an editor [message #253093 is a reply to message #252993] Thu, 03 April 2008 16:53 Go to previous message
I eventually got it to work, but I'm not sure how
Previous Topic:JUnit refuses to work
Next Topic:gnatbench
Current Time: Sat Jul 19 23:31:58 EDT 2025
Powered by FUDForum. Page generated in 0.07505 seconds
