Home » Archived » BIRT » Data Set Result used as Variable
Data Set Result used as Variable [message #252151] Mon, 13 August 2007 09:58 Go to next message
Originally posted by: Jeff.thisplace.com
Hello:
I have a data set which calculates a sum() and returns a single value. I
would like to use this value when selecting data from "another" data set in
a chart. I cannot find a way to get access to the sum() data set value when
I am using another data set in a chart.
Does anyone have an idea on how to do this?
Jeff
Re: Data Set Result used as Variable [message #252166 is a reply to message #252151] Mon, 13 August 2007 11:36 Go to previous messageGo to next message
One way of doing this is to assign the sum to a hidden parameter. Then use
that parameter in the prepared statement query of the other dataset.
For e.g.,
In the onFetch method of your first dataset that computes the sum, store
the sum in a hidden parameter X
In the second dataset write your query as select <col names> from <table
name> where <col name> = ? Bind the question mark to the parameter X
-pc
"Jeff" <Jeff@thisplace.com> wrote in message
news:f9po1m$uhm$1@build.eclipse.org...
> Hello:
> in a chart. I cannot find a way to get access to the sum() data set value
> when I am using another data set in a chart.
> Jeff
Re: Data Set Result used as Variable [message #252169 is a reply to message #252166] Mon, 13 August 2007 11:56 Go to previous messageGo to next message
Hi:
This sounds like a good approach. I tried to use a new parameter on the
dataset, but can't seem to set the parameter. The only direction option I
have is "input". No "output" available. Is there another way to set the
value of the hidden report parameter?
Jeff
"chakravp" <chakravp@us.ibm.com> wrote in message
news:f9ptj8$hg3$1@build.eclipse.org...
> For e.g.,
> -pc
>> Hello:
>> value when I am using another data set in a chart.
>> Thanks,
>> Jeff
Re: Data Set Result used as Variable [message #252173 is a reply to message #252169] Mon, 13 August 2007 12:03 Go to previous messageGo to next message
I just found in the docs that "output" parameters are only supported for
stored procedures. I'm not sure what this refers to. I have a simple SQL
statement which sums a column and returns one value. How do I get to a
stored procedure from here to support seeting the value of a report
parameter?
Jeff
news:f9puuv$rvk$1@build.eclipse.org...
> Hi:
> Jeff
>> use that parameter in the prepared statement query of the other dataset.
>> For e.g.,
>> -pc
>>> Hello:
>>> I would like to use this value when selecting data from "another" data
>>> set in a chart. I cannot find a way to get access to the sum() data set
>>> Thanks,
>>> Jeff
Re: Data Set Result used as Variable [message #252185 is a reply to message #252173] Mon, 13 August 2007 13:44 Go to previous messageGo to next message
An update on progress...
I am now obtaining the value from a stored procedure from within the DB.
This has enabled the ability to work with the data set parameter as an
output. However, when this is selected, the options to bind the output to a
report parameter become disabled.
Does anyone know how to bind a result to a report parameter?
Jeff
news:f9pvcn$uke$1@build.eclipse.org...
>parameter?
> Jeff
>> Hi:
>> I have is "input". No "output" available. Is there another way to set
>> the value of the hidden report parameter?
>> Thanks,
>> Jeff
>>> For e.g.,
>>> store the sum in a hidden parameter X
>>> -pc
>>>> Hello:
>>>> set value when I am using another data set in a chart.
>>>> Thanks,
>>>> Jeff
Re: Data Set Result used as Variable [message #252201 is a reply to message #252166] Mon, 13 August 2007 14:22 Go to previous messageGo to next message
I've located the onFetch method for the data source. How would I go about
assigning the result set to a hidden paramter? I can't seem to find any
examples.
Jeff
> For e.g.,
> -pc
>> Hello:
>> Thanks,
>> Jeff
Re: Data Set Result used as Variable [message #252227 is a reply to message #252185] Mon, 13 August 2007 17:37 Go to previous messageGo to next message
Jeff,
You don't need to make the report parameter an output.
First create a parameter for your report (not in your dataset, but on your
report, in the Report Parameters section). Say this parameter is called X.
When you create the parameter make sure the "Hidden" checkbox is checked.
Next, let us assume you have a dataset DS1 which returns a column called
SUM. From your earlier post, it seems like there will be only one value
returned by your dataset i.e., the result will have one column and one row.
In the onFetch method of the dataset DS1, assign the value of this SUM to
the parameter X by typing this code:
params["X"]=row.getColumnValue("SUM");
Now write your query for the second dataset say DS2. The query should be
select <col_names> from <table_name> where <col_name> = ?
Bind the question mark to the parameter X. In order to do that, go to the
parameters in the dataset editor once you have entered the query and select
"X" for the Link to Report Parameter box.
Now bind DS1 with a blank label and make this invisible. The label should be
placed before the chart. When this element gets loaded, DS1 is called, SUM
is computed and assigned to parameter X. Next when the chart is called which
is bound to DS2, DS2 will use the value of parameter X.
This way the value from one dataset can be fed to another dataset by using a
parameter that remains hidden.
Though this works, there might be a better way to handle this with your
query.
-pc
news:f9q5au$rp0$1@build.eclipse.org...
> a report parameter become disabled.
> Jeff
>>parameter?
>> Thanks,
>> Jeff
>>> Hi:
>>> Thanks,
>>> Jeff
>>>> dataset.
>>>> For e.g.,
>>>> <table name> where <col name> = ? Bind the question mark to the
>>>> parameter X
>>>> -pc
>>>>> Hello:
>>>>> Thanks,
>>>>> Jeff
Re: Data Set Result used as Variable [message #252247 is a reply to message #252227] Mon, 13 August 2007 20:11 Go to previous message
PC:
Thanks for the direction on this. I managed to get it to work, with one
minor adjustment. When I call row.getColumnValue, I get an error that
states the method does not exist. Kind of wierd to since the context help
indicates the method is there. I did a search on this, and found others
having the same problem. row["column_name"]; did the trick.
Thanks again for your help!
Jeff
news:f9qio6$qr3$1@build.eclipse.org...
> Jeff,
> row.
> select "X" for the Link to Report Parameter box.
> be placed before the chart. When this element gets loaded, DS1 is called,
> SUM is computed and assigned to parameter X. Next when the chart is called
> which is bound to DS2, DS2 will use the value of parameter X.
> a parameter that remains hidden.
> query.
> -pc
>> to a report parameter become disabled.
>> Thanks,
>> Jeff
>>>SQL statement which sums a column and returns one value. How do I get to
>>>a stored procedure from here to support seeting the value of a report
>>>parameter?
>>> Thanks,
>>> Jeff
>>>> Hi:
>>>> the dataset, but can't seem to set the parameter. The only direction
>>>> option I have is "input". No "output" available. Is there another way
>>>> to set the value of the hidden report parameter?
>>>> Thanks,
>>>> Jeff
>>>>> dataset.
>>>>> For e.g.,
>>>>> parameter X
>>>>> -pc
>>>>>> Hello:
>>>>>> value. I would like to use this value when selecting data from
>>>>>> "another" data set in a chart. I cannot find a way to get access to
>>>>>> the sum() data set value when I am using another data set in a chart.
>>>>>> Thanks,
>>>>>> Jeff
Previous Topic:Drop down values are not in ascending order
Next Topic:Birt 2.2 - parameter setting in java event handler
Current Time: Sat Jul 19 19:37:07 EDT 2025
Powered by FUDForum. Page generated in 0.24672 seconds
