Home » Language IDEs » Java Development Tools (JDT) » Java3D
Java3D [message #251614] Fri, 22 February 2008 23:46 Go to next message
Originally posted by: jolyqr.gmail.com
Hello there !!
I've installed Java3D and I'm trying to run it using eclipse, but I'm
getting the following error :
java.lang.UnsupportedClassVersionError: Bad version number in .class file
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$100(Unknown Source)
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
Exception in thread "main"
I have even set all paths leading to Java3D jars, but it's not working...
Cheers
Joly
Re: Java3D [message #251618 is a reply to message #251614] Sat, 23 February 2008 07:23 Go to previous message
Joly,
I'd expect this kind of error if you try to run a class compiled for
Java 5.0 on a 1.4 JVM. I.e., it's a mismatch between the runtime
version targeted by the compiler and the one you are actually using to run.
jolyqr wrote:
> Hello there !!
> at java.security.AccessController.doPrivileged(Native Method)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> Cheers
> Joly
Previous Topic:Disable searching through JSP indexes?
Next Topic:How to translate a java stack trace into an other language stack trace ?
Current Time: Sat Jul 19 06:55:07 EDT 2025
Powered by FUDForum. Page generated in 0.03531 seconds
