| Reports using Web services [message #250906] |
Thu, 02 August 2007 03:55  |
Originally posted by: msjumbu.gmail.com
I have created a report, which uses the web services data source.
While creating the dataset, in the column mapping screen, I select the
fields required. In the same screen, below there is a table preview option.
I press the "Preview the result set" button, it gets the data from the web
service and displays it.
But when I go the preview results screen or try viewing the report, the CPU
goes to 100% and remains like that till the timeout occurs.
Can you please tell me what could be the problem?
Senthil
| Re: Reports using Web services [message #251017 is a reply to message #250906] |
Thu, 02 August 2007 20:47  |
Hi Senthil,
Can you give me your wsdl url or your wsdl file? I have tried in my build,
when preview the CPU Usage is very slow. I guess there are huge number of
rows you got when preview. Try to set the "Max number of rows fetch from
data sources" in Dataset's setting page and check whether the CPU Usage is
still 100%. If reproduceable, please log a bug and describe more detail
info in the bug.
Regards!
FUDForum. Page generated in 0.04908 seconds
