Home » Newcomers » Newcomers » open declaration problem
open declaration problem [message #250029] Sun, 24 February 2008 09:38 Go to next message
Originally posted by: wen.g.he.gmail.com
Hi:
I downloaded from sun.com the SDK file java_ee_sdk-5_01-windows.exe
and installed it in E:/SUN/SDK.
I would like to see the source code of the built-in classes, so I select a
type in a .java file, say String, then right click and select Open
Declaration. Then I got "souce not found", and I click button "attach
source.." and set the source to E:/SUN/SDK/jdk/jre/lib/rt.jar
But I still get "source not found" error.
How can I fix this please?
Thank you very much
Wen
Re: open declaration problem [message #250039 is a reply to message #250029] Sun, 24 February 2008 12:36 Go to previous messageGo to next message
Originally posted by: cboe.news.eclipse.org
On Sun, 2008-02-24 at 14:38 +0000, Wen wrote:
> Hi:
> Thank you very much
> Wen
rt.jar is a jar file with the compiled class files. You need to attach
the actual source code. Sun provides source in a file called src.zip.
I believe you normally have to specifically select the option to install
source when installing the sdk.
Re: open declaration problem [message #250076 is a reply to message #250039] Mon, 25 February 2008 03:22 Go to previous messageGo to next message
Hi David:
I am using Java Platform, Enterprise Edition 5 SDK Update 1
I ran through the installation again, and found no explicit option to
install src.zip.
After I re-installed the SDK, I did a search on the folder SDK and found
no src.zip at all.
Questions:
Does anyone know how to fix it?
Could the source code file in this SDK version be named differently?
If this version doesn't come with the source code file, can I download it
somewhere individually?
thank you very much
Wen
Re: open declaration problem [message #250080 is a reply to message #250076] Mon, 25 February 2008 03:36 Go to previous messageGo to next message
Hey Wen,
I don't know if the source attachment comes with the Enterprise Edition.
But from all my previous experiences, the src.zip came automatically
with the Standard Edition SDK. I never had to specify any options. You
might want to download this and look there. In my current installation
it is located directly in the SDK root folder.
Felix
Re: open declaration problem (suggestion) [message #250188 is a reply to message #250029] Tue, 26 February 2008 01:42 Go to previous messageGo to next message
Basing on the problem I encountered, can I make a suggestion to the
according development team?
When I tried to attached the source code for Open Declaration, the I got
the message in Eclipse asking me to find rt.jar, so obviously this needs
to change to src.zip.
Can anyone forward my suggestion to the concerned person?
Thank you
Wen
Re: open declaration problem (suggestion) [message #250196 is a reply to message #250188] Tue, 26 February 2008 03:50 Go to previous messageGo to next message
> got the message in Eclipse asking me to find rt.jar, so obviously this
> needs to change to src.zip.
Please file a bug
(https://bugs.eclipse.org/bugs/enter_bug.cgi?product=JDT) with the steps
you made.
Dani
> Thank you
> Wen
Re: open declaration problem [message #754639 is a reply to message #250029] Thu, 03 November 2011 13:25 Go to previous message
Here is my src.zip location. FInd your appropriate location. enjoy eclip:D
C:\Program Files\Java\jdk1.6.0_24\src.zip
Previous Topic:PAR project runtime and deploy error
Next Topic:Eclipse and Analog Devices SHARC DSP
Current Time: Sat Jul 19 08:12:44 EDT 2025
Powered by FUDForum. Page generated in 0.09523 seconds
