Home » Eclipse Projects » GEF » the right way to deal with requests
the right way to deal with requests [message #248822] Wed, 06 May 2009 12:21 Go to next message
hi folks,
i want to create components in my diagram via the context menu of my
editor. therefore i added a action that create a CreateRequest and a
CreationFactory. The next step was that i called the
performRequest-method of my responsible editpart. but the default
implementation of this method is empty and i have to implement the
method myself. but i m in doubt how i do this. can you please give me
some hints what are the next steps? is it possible to determine the
position where the context menu was opened?
Re: the right way to deal with requests [message #248828 is a reply to message #248822] Wed, 06 May 2009 12:22 Go to previous messageGo to next message
i forgot something :)
thanks in advance!
best regards,
rené
Re: the right way to deal with requests [message #248832 is a reply to message #248822] Wed, 06 May 2009 13:09 Go to previous messageGo to next message
Regarding the location of the context menu,
http://wiki.eclipse.org/index.php/GEF_Developer_FAQ#How_do_I _find_the_location_of_the_context_menu.3F
-Ben
René wrote:
> hi folks,
Re: the right way to deal with requests [message #248837 is a reply to message #248832] Wed, 06 May 2009 14:19 Go to previous messageGo to next message
Originally posted by: alamothe.ptt.yu
That doesn't help at all, the author of the FAQ was just being a smartass.
They should have explained how to find the location of the context menu if
it was brought via mouse. I'm sure that GMF creates parts via the context
menu, so what is the problem?
> -Ben
> Ren
Re: the right way to deal with requests [message #248842 is a reply to message #248837] Wed, 06 May 2009 21:57 Go to previous messageGo to next message
The entry is not suggesting that you can't create new parts using the
context menu.
It seems like good advice to me that you shouldn't rely on a location
that may not work in all scenarios.
If you have a snippet to get the context menu location, please post it.
Ben
>> -Ben
>> René wrote:
>>> hi folks,
Re: the right way to deal with requests [message #248857 is a reply to message #248842] Thu, 07 May 2009 20:11 Go to previous messageGo to next message
AbstractTool tool = (AbstractTool) editDomain.getActiveTool();
Method m = AbstractTool.class.getDeclaredMethod("getLocation");
m.setAccessible(true);
location = (Point) m.invoke(tool);
You also need to traslate the point, take a look at
org.eclipse.gef.editpolicies.ConstrainedLayoutEditPolicy on how to do this
> context menu.
> it.
> Thanks
> Ben
>> smartass. They should have explained how to find the location of the
>> context menu if it was brought via mouse. I'm sure that GMF creates
>> parts via the context menu, so what is the problem?
>>> -Ben
>>> Ren
Re: the right way to deal with requests [message #248988 is a reply to message #248857] Fri, 15 May 2009 06:03 Go to previous messageGo to next message
hey folks,
thanks for your many many replies. unfortunately i was very busy the
last 2 weeks, so that i have today the first chance to look at your posts.
you have post a lot to determine the location where the actions is
performed. thanks for that. maybe you can give me a short overview how
to deal with request? that would very useful.
thanks again and regards,
rené
>> context menu.
>> it.
>> Thanks
>> Ben
>>>> -Ben
>>>> René wrote:
>>>>> hi folks,
>>>>> my editor. therefore i added a action that create a CreateRequest
>>>>> and a CreationFactory. The next step was that i called the
>>>>> me some hints what are the next steps? is it possible to determine
>>>>> the position where the context menu was opened?
Re: the right way to deal with requests [message #248993 is a reply to message #248988] Fri, 15 May 2009 11:49 Go to previous message
hey,
its me again. i solved the problem with the request. it was much easier
than i thought. you have to call just getCommand(Request) of the
responsible edit part. this uses the registered edit policies to create
and return the correct command...
i just want to thank you again. specially nikolas post was very helpful
and works immediately. the use of reflection to get the drop location is
a nice hack and i properly have to pondering for years to come to this
idea. btw: i didn't have to translate the location. it was out of the
box relative to my diagram domain.
best regards,
rené
René wrote:
> hey folks,
> rené
>> this
>>> context menu.
>>> it.
>>> Thanks
>>> Ben
>>>>> -Ben
>>>>> René wrote:
>>>>>> hi folks,
Previous Topic:AbstractBackground
Next Topic:copy paste issue
Current Time: Sun Jul 20 06:17:15 EDT 2025
Powered by FUDForum. Page generated in 0.04298 seconds
