Home » Eclipse Projects » Eclipse Platform » CVS merge - Root Version Tag
CVS merge - Root Version Tag [message #248343] Wed, 02 June 2004 08:08 Go to next message
Originally posted by: bob.news.gmx.net
Hi all,
when doing a CVS merge Eclipse needs the tag of the root version where the
branch originated. While this is not a problem if branching has been done
via Eclipse, obviously this tag is absent if it has been done with some
other tool. I can understand that it's a nice feature to have, to select
this by hand, so we can make arbitrary three way merges. But why is there
no feature to figure the version automatically. Other tools do it that
way AFAIK.
Is there any inherent reason why this does not work / is a bad idea(TM)?
Thanks for some enlightenment!
Kind regards
robert
Re: CVS merge - Root Version Tag [message #248487 is a reply to message #248343] Wed, 02 June 2004 14:57 Go to previous messageGo to next message
Hi Robert,
You should always tag the starting point when merging. It is a well
known CVS best-pratice, but of course, isn't enforced by the tool. If
you did branch with the command line, then the current workaround for
Eclipse's lack of one tag merges, is to use the command line to perform
the merge.
Here is some background - the eclipse cvs client tries to show a preview
of the merge ahread of time. Having both the start and end tags provided
the best way for supporting multiple merges and calculating the preview.
If we only had one tag, as a client, it's hard to calculate the base
revisions for all files in the branch. When you run update -r tag, the
server does this for you and is better at figuring this out.
One possibility is to allow a merge via the new CVS update wizard. You
would pick a tag and then instead of a vanilla update it would merge
instead.
I've logged a bug for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=65420
Jean-Michel
Robert Klemme wrote:
> Hi all,
> way AFAIK.
> Kind regards
> robert
Re: CVS merge - Root Version Tag [message #248699 is a reply to message #248487] Thu, 03 June 2004 03:58 Go to previous messageGo to next message
"Jean-Michel Lemieux" <jean-michel_lemieux@ca.ibm.com> schrieb im
Newsbeitrag news:c9l7fp$q2b$1@eclipse.org...
> Hi Robert,
> the merge.
Well, I wouldn't like to - with a tool like Eclipse, CVS command line
looks really clumsy. In that case I'd prefer to set the tag afterwards so
I can use Eclipse for merging.
In order to set the tag I needed to emulate this calculation. I did a
little scripting that uses "cvs -N -S log -r<my branch> | egrep '^date:' |
sort" to extract all dates on the branch to find the oldest date on the
branch. After that I tagged all versions on the branch my branch did
originate from using the timestamp minus a second. Not nice and not fast,
but maybe you can add such a feature as a Wizard to Eclipse. I'm sure
that will help people a lot that work on projects that did their CVS
without Eclipse.
Would you mind if I record this as a feature request in bugzilla?
Yeah, and it's most likely faster.
> instead.
Ok, thanks!
Kind regards
robert
> Cheers,
> Jean-Michel
> > Hi all,
the
done
some
select
there
that
> > way AFAIK.
idea(TM)?
> > Kind regards
> > robert
Re: CVS merge - Root Version Tag [message #248726 is a reply to message #248699] Thu, 03 June 2004 06:28 Go to previous messageGo to next message
>>Hi Robert,
>>the merge.
Ack :) I could never use the command line again...
> without Eclipse.
Yes we thought of this too, if we supported selecting a date as the
start tag this would work. Please enter a feature request for this. This
isn't high on our priority list so if you are keen and would like to
see this feature, please consider providing a patch.
>>instead.
> Ok, thanks!
> Kind regards
> robert
>>Cheers,
>>Jean-Michel
>>>Hi all,
> the
> done
> some
> select
> there
> that
>>>way AFAIK.
> idea(TM)?
>>>Kind regards
>>> robert
Re: CVS merge - Root Version Tag [message #248750 is a reply to message #248726] Thu, 03 June 2004 07:04 Go to previous message
Newsbeitrag news:c9mu0n$qa7$1@eclipse.org...
Thanks for listening, Jean-Michel!
afterwards so
Even WinCVS and JBuilder's CVS support are way behind Eclipse. You folks
did a really great Job here!
'^date:' |
the
fast,
> > without Eclipse.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=65520
I included the description from above also.
Kind regards
robert
Previous Topic:strange behavior of JavaCore.getClasspathVariable() in 3.0RC1
Next Topic:Eclipse M8 :: Installation ?
Current Time: Sat Jul 19 22:02:41 EDT 2025
Powered by FUDForum. Page generated in 0.05942 seconds
