Home » Eclipse Projects » GEF » Automatic layout size in Zest
Automatic layout size in Zest [message #246815] Fri, 09 January 2009 07:20 Go to next message
Originally posted by: csaad.gmx.net
I'd like to know wheter there is any possibility to let Zest compute the
optimal size for the layouted graph instead of passing the required size
in the applyLayout() method.
The problem with the specification of a concrete size is that it depends
of the number of elements and the selected layouting algorithm, so it is
not possible to do this automatically without manual adjustments by the
user.
Chris
Re: Automatic layout size in Zest [message #246858 is a reply to message #246815] Wed, 14 January 2009 11:51 Go to previous messageGo to next message
Originally posted by: irbull.cs.uvic.ca
C. Saad wrote:
In general, no. Spring algorithms (for example) would continue to push
away forever, if it was not bounded. However, tree based algorithms
could probably be made to work this way.
Can you file an enhancement request under GEF->Zest for this?
> user.
> Chris
Re: Automatic layout size in Zest [message #246891 is a reply to message #246858] Thu, 15 January 2009 04:02 Go to previous message
Hi Ian,
thanks for your answer. I've entered the request in bugzilla (261163).
Chris
Ian Bull wrote:
> C. Saad wrote:
>> Hi,
>> user.
>> Thanks,
>> Chris
Previous Topic:[Announce] GEF 3.5.0 I200901141304 is available
Next Topic:Divinding a figure
Current Time: Sat Jul 19 23:49:08 EDT 2025
Powered by FUDForum. Page generated in 0.02717 seconds
