Home » Archived » BIRT » Specifying DataSource outside of report
Specifying DataSource outside of report [message #246313] Wed, 04 July 2007 11:46 Go to next message
I'm looking for a way to override the datasource defined in the report at
runtime. When I need to achieve is:
1. Pass in a DataSource object from JUnit tests (connects to local Derby
database)
2. Pass DataSource to real database from command line tool
3. Pass pooled JNDI DataSource from Tomcat into the report.
I understand that I can achieve #3 with defining a JNDI DataSource in the
report but I haven't found a way yet to do #1 and #2. Currently, I'm using
2.1.2.
Any pointers?
Aaron Digulla
Re: Specifying DataSource outside of report [message #246318 is a reply to message #246313] Wed, 04 July 2007 12:08 Go to previous messageGo to next message
Originally posted by: Martin.Ahrer.gmx.at
For #1 & #2 you can just create your own data source and associate it
with the database and jndi url -> Just behave like if you are a
container (like tomcat)
use the apache naming components and set up a data source with some XML
as shown below
<?xml version="1.0" encoding="utf-8"?>
<naming>
<context>
<resource name="jdbc/dsname" type="javax.sql.DataSource">
<parameter>
<name>factory</name>
<value>org.apache.commons.dbcp.BasicDataSourceFactory</value >
</parameter>
<parameter>
<name>driverClassName</name>
<value>oracle.jdbc.OracleDriver</value>
</parameter>
<parameter>
<name>url</name>
<value>jdbc:oracle:thin:@server:1526:inst</value>
</parameter>
<parameter>
<name>username</name>
<value>???</value>
</parameter>
<parameter>
<name>password</name>
<value>??</value>
</parameter>
</resource>
</context>
</naming>
Aaron Digulla schrieb:
> Hello,
> at runtime. When I need to achieve is:
> database)
> the report but I haven't found a way yet to do #1 and #2. Currently, I'm
> using 2.1.2.
> Any pointers?
> Regards,
> Aaron Digulla
Re: Specifying DataSource outside of report [message #246467 is a reply to message #246318] Thu, 05 July 2007 08:45 Go to previous message
>> database)
Good idea. I'm already using mockejb which comes with a JNDI context so
setting up my own context (even without XML) is easy. The report designer,
I can use BIRT's fallback mechanism as described on
http://wiki.eclipse.org/BIRT/FAQ/Data_Access#Q:_What_is_the_ precedence_when_both_JDBC_URL_and_JNDI_name_are_specified.3F
Aaron Digulla
Previous Topic:Yellowfin 3.2 release notes
Next Topic:Birt and Hibernate Help
Current Time: Sat Jul 19 13:00:38 EDT 2025
Powered by FUDForum. Page generated in 0.04996 seconds
