Home » Language IDEs » Java Development Tools (JDT) » ASTParser Help
ASTParser Help [message #240639] Sun, 11 February 2007 09:32 Go to next message
Originally posted by: nitrousfiz.googlemail.com
Can I use Eclipse's ASTParser to parse java source code from a standalone
application (i.e. without the null pointed exception)?
If yes, which version should I use?
If not, what alternatives are there for parsing java code?
Here is what I need to do-
Use a parser to create an AST and extract the names of the methods, its
parameters & its parameter types. I also need to extract variable names &
variable types from a given set of statements.
Please help me out to get this done.
Thanks for your help in advance.
Fayezin
Re: ASTParser Help [message #240643 is a reply to message #240639] Sun, 11 February 2007 09:39 Go to previous messageGo to next message
Fayezin,
I believe this should be possible. Perhaps if you show what you've
tried and show the exception stack trace someone, will know what you
need to do to avoid it.
Fayezin Islam wrote:
> Hello,
> Regards,
> Fayezin
Re: ASTParser Help [message #240648 is a reply to message #240643] Sun, 11 February 2007 14:06 Go to previous messageGo to next message
This is the program I am trying to run:
import java.io.*;
import org.eclipse.jdt.core.dom.*;
public class ParseJava {
ASTParser parser = ASTParser.newParser(AST.JLS3);
parser.setSource(code.toCharArray());
parser.setKind(ASTParser.K_EXPRESSION);
ASTNode node = parser.createAST(null);
if (node.getNodeType() == ASTNode.METHOD_INVOCATION) {
MethodInvocation methodInvocation = (MethodInvocation) node;
System.out.println("Invoking method : "+methodInvocation.getName());
I get this error during compilation (maybe its asking for the runtime?)-
The type org.eclipse.core.runtime.IProgressMonitor cannot be resolved. It is
indirectly referenced from required .class files
I am using the org.eclipse.jdt.core_3.2.1.v_677_r32x.jar in my buildpath.
If its the wrong one, please advise which one to use?
Can you please help me solve this problem?
Fayezin
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:eqn9rs$ql$1@utils.eclipse.org...
> Fayezin,
> I believe this should be possible. Perhaps if you show what you've tried
> and show the exception stack trace someone, will know what you need to do
> to avoid it.
>> Hello,
>> Regards,
>> Fayezin
Re: ASTParser Help [message #240663 is a reply to message #240648] Sun, 11 February 2007 16:43 Go to previous messageGo to next message
--------------070606070704050207030907
Fayezin,
It sounds like you still need to put all of jdt's dependencies on the
classpath. E.g., IProgressMonitor is in org.eclips.equinox.common_*.jar.
> Hello,
> import java.io.*;
> public static void main(String[] args) {
> Fayezin
>> Fayezin,
>> to avoid it.
>>> Hello,
>>> Regards,
>>> Fayezin
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Fayezin,<br>
<br>
classpath.&nbsp; E.g., IProgressMonitor is in
org.eclips.equinox.common_*.jar.<br>
<br>
<br>
<blockquote cite="mideqnpfi$t4g$1@utils.eclipse.org" type="cite">
<pre wrap="">Hello,
import java.io.*;
Fayezin
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:eqn9rs$ql$1@utils.eclipse.org">news:eqn9rs$ql$1@utils.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Fayezin,
to avoid it.
</pre>
<pre wrap="">Hello,
parameters &amp; its parameter types. I also need to extract variable names &amp;
Fayezin
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------070606070704050207030907--
Re: ASTParser Help [message #240668 is a reply to message #240648] Sun, 11 February 2007 21:32 Go to previous messageGo to next message
It can run inside a standalone application as long as you are not using
Javamodel element (IJavaProject, ICompilationUnit).
Even if you don't use any java element, you need to put some jars on the
classpath in order to find some classes required to resolve some signatures.
Olivier
Re: ASTParser Help [message #240713 is a reply to message #240668] Tue, 13 February 2007 19:30 Go to previous messageGo to next message
Many thanks for your replies. It really helped a lot!
Now that I have added the requred jars, I am able to create a
CompilationUnit object from the source code.
I dont know how to extract the method & parameter names & variable names
from a CompilationUnit object.
Please advice how can I do it.
Thanks & Regards,
Fayezin
"Olivier Thomann" <olivier_thomann@ca.ibm.com> wrote in message
news:eqojka$9ki$1@utils.eclipse.org...
> Fayezin Islam a
Re: ASTParser Help [message #240718 is a reply to message #240713] Tue, 13 February 2007 19:45 Go to previous messageGo to next message
The CompilationUnit node that you have is a node tree.
If you want to extract method names, parameter names or variable names,
you can simply define a org.eclipse.jdt.core.dom.ASTVisitor. Then you
define the method like:
visit(MethodDeclaration)
visit(VariableDeclarationFragment)
visit(SingleVariableDeclaration).
If you have troub;e with this, you might want to read the article about AST.
See
http://www.eclipse.org/articles/Article-JavaCodeManipulation _AST/index.html.
HTH,
Olivier
Re: ASTParser Help [message #246155 is a reply to message #240713] Wed, 25 July 2007 10:49 Go to previous messageGo to next message
Originally posted by: chengt.uwm.edu
I tried your example, and I get this error. I'm using jar files from
eclipse 3.2.2.
Exception in thread "main" java.lang.NoClassDefFoundError:
org/eclipse/core/runtime/Plugin
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$000(Unknown Source)
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at
org.eclipse.jdt.core.dom.ASTParser.initializeDefaults(ASTPar ser.java:230)
at org.eclipse.jdt.core.dom.ASTParser.<init>(ASTParser.java:212)
at org.eclipse.jdt.core.dom.ASTParser.newParser(ASTParser.java: 112)
at test.Test.main(Test.java:23)
> Thanks & Regards,
> Fayezin
>>> is indirectly referenced from required .class files I am using the
>> signatures.
>> Olivier
Re: ASTParser Help [message #246159 is a reply to message #246155] Wed, 25 July 2007 12:54 Go to previous messageGo to next message
> at java.security.AccessController.doPrivileged(Native Method)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
You can get this if you don't have all the required jars on your classpath.
Olivier
Re: ASTParser Help [message #246161 is a reply to message #246159] Wed, 25 July 2007 14:14 Go to previous messageGo to next message
>> at
> Olivier
org/eclipse/core/runtime/content/IContentTypeManager$IConten tTypeChangeListener
I added many more jar files. Now it needs the IContentTypeManager which
I can't seem to find the jar that has it. I assume it is in the
org.eclipse.core.runtime.jar. I tried that, but it didn't work. I look
at the source code in org.eclipse.core.runtime.content, but there is no
IContentTypeManager.
I'm using Eclipse 3.2.2.
Re: ASTParser Help [message #246170 is a reply to message #246161] Wed, 25 July 2007 15:19 Go to previous message
>>> at
>> classpath.
>> Olivier
OK, this is fixed. I had to include the following jar files.
org.eclipse.core.contenttype.jar
org.eclipse.core.jobs.jar
org.eclipse.core.resources.jar
org.eclipse.runtime.jar
org.eclipse.equinox.common.jar
org.eclipse.equinox.preferences.jar
org.eclipse.jdt.core.jar
org.eclipse.osgi.jar
Previous Topic:Re: Request about Importing Java Compiler
Next Topic:eclipse plugin generator problem
Current Time: Sat Jul 19 15:37:00 EDT 2025
Powered by FUDForum. Page generated in 0.05092 seconds
