Home » Language IDEs » Java Development Tools (JDT) » Calling Refactorings Programmatically
Calling Refactorings Programmatically [message #245512] Wed, 11 July 2007 13:43 Go to next message
I want to use Eclipse refactorings programmatically. As far as I can see
the only way to do this is to use internal classes.
For example to rename a compilation unit I would need to use
org.eclipse.jdt.internal.corext.refactoring.rename.RenameCom pilationUnitProcessor
Is this correct? That I can only use the refactorings that Eclipse ships
by using internal classes?
If so does this break the guidelines for using the Eclipse API as outlined
on this page?
http://www.eclipse.org/articles/article.php?file=Article-API -Use/index.html
If so, does this mean that one cannot safely use Eclipse refactorings
programmatically?
On a related note, with regards developing custom refactorings I see even
Tobias Widmer in his article "Unleashing the Power of Refactoring"
http://www.eclipse.org/articles/article.php?file=Article-Unl eashing-the-Power-of-Refactoring/index.html
uses internal classes (org.eclipse.jdt.internal.corext.dom.NodeFinder) in
order to develop his custom refactoring.
Once again, is this not bad practice at a minimum and unsafe with regards
it breaking when running against future releases of Eclipse due to
dependencies on internal API?
I want to develop some custom refactorings - is it just the case that in
order to develop custom refactorings I will more than likely need to use
some internal classes? And the best I can do is to request any internal
API I use to be put into the published API in the future and fix things
down the line, whilst in the meantime dealing with any breakage in the
code between Eclipse releases due to dependencies on internal API?
Any help greatly appreciated,
Máirtín
Re: Calling Refactorings Programmatically [message #245652 is a reply to message #245512] Fri, 13 July 2007 04:36 Go to previous messageGo to next message
Originally posted by: jacek.pospychala.pl.ibm.com
Máirtín,
You're right, accessing RenamCompilationUnitProcessor directly from your
code is not a good idea.
Please take a look at org.eclipse.ltk (Refactoring Language Toolkit)
framework. Also this article should give you some hints on how to use
refactorings:
> see the only way to do this is to use internal classes.
> ships by using internal classes?
> outlined on this page?
> programmatically?
> even Tobias Widmer in his article "Unleashing the Power of Refactoring"
> in order to develop his custom refactoring.
> regards it breaking when running against future releases of Eclipse
> in order to develop custom refactorings I will more than likely need
> to use some internal classes? And the best I can do is to request any
> internal API I use to be put into the published API in the future and
> fix things down the line, whilst in the meantime dealing with any
> breakage in the code between Eclipse releases due to dependencies on
> internal API?
> Máirtín
Re: Calling Refactorings Programmatically [message #245662 is a reply to message #245652] Fri, 13 July 2007 05:22 Go to previous messageGo to next message
> refactorings:
Yes, I had a look at that article:
>> internal API?
And my point was that even in this article Tobias Widmer uses internal
classes - so my question was is it the case that it is virtually
impossible to use refactorings that are provided by Eclipse
programmatically without using internal classes.
Re: Calling Refactorings Programmatically [message #245682 is a reply to message #245662] Fri, 13 July 2007 06:32 Go to previous messageGo to next message
Máirtín,
I wonder, if this is the preferred way, but you may try the following
code to create a refactoring through API:
ICompilationUnit cu = ... // an ICompilationUnit to rename
RefactoringContribution contribution =
RefactoringCore.getRefactoringContribution(IJavaRefactorings .RENAME_COMPILATION_UNIT);
RenameJavaElementDescriptor descriptor =
(RenameJavaElementDescriptor) contribution.createDescriptor();
descriptor.setProject(cu.getResource().getProject().getName( ));
descriptor.setNewName("NewClass"); // new name for a Class
descriptor.setJavaElement(cu);
RefactoringStatus status = new RefactoringStatus();
try {
Refactoring refactoring = descriptor.createRefactoring(status);
IProgressMonitor monitor = new NullProgressMonitor();
refactoring.checkInitialConditions(monitor);
refactoring.checkFinalConditions(monitor);
Change change = refactoring.createChange(monitor);
change.perform(monitor);
} catch (CoreException e) {
e.printStackTrace();
} catch (Exception e) {
>> Also this article should give you some hints on how to use refactorings:
>>> (org.eclipse.jdt.internal.corext.dom.NodeFinder) in order to develop
>>> that in order to develop custom refactorings I will more than likely
>>> need to use some internal classes? And the best I can do is to
>>> request any internal API I use to be put into the published API in
>>> the future and fix things down the line, whilst in the meantime
>>> dealing with any breakage in the code between Eclipse releases due
Re: Calling Refactorings Programmatically [message #245692 is a reply to message #245682] Fri, 13 July 2007 07:17 Go to previous messageGo to next message
> try {
Thanks, I'll give that a try for using Eclipse's refactorings.
Re: Calling Refactorings Programmatically [message #246998 is a reply to message #245682] Thu, 23 August 2007 09:31 Go to previous messageGo to next message
> Máirtín,
> try {
I am using the code above to call the refactoring that Eclipse provides to
rename a compilation unit.
I would like to be able to get a list of the files that the refactoring is
about to modify (before it does so). So, looking at the code above, before
making a call to
I would like to get a handle to the list of files that are about to be
changed.
Is there a way of getting a hold on this list of files without carrying
out the search again myself?
I see that internally the class
org.eclipse.ltk.core.refactoring.participants.RenameRefactor ing
(which is extended by JavaRenameRefactoring) has a reference to a
which has a reference to a
org.eclipse.jdt.internal.corext.refactoring.rename.RenameTyp eProcessor
which contains a field
private SearchResultGroup[] fReferences
that contains the list to all the references to that will be updated by
this refactoring.
The method
initializeReferences
from the class
contains the code that carries out the search for these references. I
would rather not have to recreate this myself, not only to save on
duplicate code but this code also uses internal classes which I do not
want to use.
Does anyone know if it is possible to get a handle on the list of files
that are about to be modified without carrying out the search myself?
Or is there any way through the public API that I can get the same
functionality as the method initializeReferences?
Máirtín
Re: Calling Refactorings Programmatically [message #749370 is a reply to message #246998] Tue, 25 October 2011 03:18 Go to previous message
Hi all, Máirtín
As you Máirtín I want to program some custom refactorings.
I read the paper of Tobias Widmer and also the blog from Anulfor Rodriguez.
But I have still some general questions
1) Is there a more recent document on ingineering refactoring in Eclipse ?
(the Java doc is not the best to understand the global process).
2) How to easily reuse and extend or specialise the existing JDT refactoring?
Is there an another way than using org.eclipse.jdt.ui.refactoring.*Descriptors ?
3) I need to pipe several refactoring actions, How to do that efficiently
with the change mechanism ?
(the existing scripting mechanism does not seem adequate)
any help is welcome
regards
Previous Topic:JadClipse not opening class files
Next Topic:how to change the line background color when my mouse move it
Current Time: Sat Jul 19 16:53:10 EDT 2025
Powered by FUDForum. Page generated in 0.04230 seconds
