Home » Eclipse Projects » GEF » Problem saving Draw2d diagram to image from within plugin (works standalone)
Problem saving Draw2d diagram to image from within plugin (works standalone) [message #244297] |
Tue, 15 July 2008 04:00  |
I have a draw2d only (no gef involved) diagram, to be saved as image
without presenting the diagram.
In standalone SWT application I am able to save diagram as image - but
this doesn't work when done from within plugin.
What could be going wrong? Please help.
Code when run from SWT application:
public class UMLClassFigureTest {
public static void main(String args[]) {
final Display display = new Display();
Shell shell = new Shell(display);
shell.setText("UML Class Diagram");
shell.setBounds(10, 10, 200, 200);
Button button = new Button(shell, SWT.PUSH);
button.setText("Play");
button.setBounds(10, 140, 50, 20);
final TheDiagram diagram = new TheDiagram();
diagram.initialize();
button.addListener(SWT.Selection, new Listener() {
public void handleEvent(Event event) {
doPlay(display, diagram);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
private static void doPlay(final Display display,
final TheDiagram internalDemo2) {
Image img1 = new Image(null, new org.eclipse.swt.graphics.Rectangle(10,
102, 600, 600));
GC gc1 = new GC(img1);
Graphics grap1 = new SWTGraphics(gc1);
internalDemo2.contents.paint(grap1);
ImageLoader loader1 = new ImageLoader();
loader1.data = new ImageData[] { img1.getImageData() };
loader1.save("draw2d.jpeg", SWT.IMAGE_JPEG);
img1.dispose();
gc1.dispose();
Code when run from plugin:
Shell shell =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getShel l();
diagram.initialize(shell);
102, 600, 600));
diagram.contents.paint(grap1);
loader1.data = new ImageData[] {img1.getImageData()};
loader1.save("e:\\draw2d.jpeg", SWT.IMAGE_JPEG);
img1.dispose();
gc1.dispose();
Re: Problem saving Draw2d diagram to image from within plugin (works standalone) [message #244304 is a reply to message #244297] |
Tue, 15 July 2008 04:03   |
Here is the entire SWT application for reference (where saving to image
works):
* Created on Jul 9, 2008
* TODO To change the template for this generated file go to
* Window - Preferences - Java - Code Style - Code Templates
package com.vikramsjn.swtapp.componenttoimage;
import org.eclipse.draw2d.AbstractBorder;
import org.eclipse.draw2d.ChopboxAnchor;
import org.eclipse.draw2d.ColorConstants;
import org.eclipse.draw2d.ConnectionEndpointLocator;
import org.eclipse.draw2d.Figure;
import org.eclipse.draw2d.Graphics;
import org.eclipse.draw2d.IFigure;
import org.eclipse.draw2d.Label;
import org.eclipse.draw2d.LightweightSystem;
import org.eclipse.draw2d.LineBorder;
import org.eclipse.draw2d.PolygonDecoration;
import org.eclipse.draw2d.PolylineConnection;
import org.eclipse.draw2d.SWTGraphics;
import org.eclipse.draw2d.ToolbarLayout;
import org.eclipse.draw2d.XYLayout;
import org.eclipse.draw2d.geometry.Insets;
import org.eclipse.draw2d.geometry.PointList;
import org.eclipse.draw2d.geometry.Rectangle;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Color;
import org.eclipse.swt.graphics.Font;
import org.eclipse.swt.graphics.GC;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.graphics.ImageData;
import org.eclipse.swt.graphics.ImageLoader;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Event;
import org.eclipse.swt.widgets.Listener;
import org.eclipse.swt.widgets.Shell;
* A test class to display a UMLFigure
shell.open();
display.sleep();
display.dispose();
102, 600, 600));
img1.dispose();
gc1.dispose();
class CompartmentFigure extends Figure {
public CompartmentFigure() {
ToolbarLayout layout = new ToolbarLayout();
layout.setMinorAlignment(ToolbarLayout.ALIGN_TOPLEFT);
layout.setStretchMinorAxis(false);
layout.setSpacing(2);
setLayoutManager(layout);
setBorder(new CompartmentFigureBorder());
class CompartmentFigureBorder extends AbstractBorder {
public Insets getInsets(IFigure figure) {
return new Insets(1, 0, 0, 0);
public void paint(IFigure figure, Graphics graphics, Insets insets) {
graphics.drawLine(getPaintRectangle(figure, insets).getTopLeft(),
tempRect.getTopRight());
class UMLClassFigure extends Figure {
public static Color classColor = new Color(null, 255, 255, 206);
private CompartmentFigure attributeFigure = new CompartmentFigure();
private CompartmentFigure methodFigure = new CompartmentFigure();
public UMLClassFigure(Label name) {
setBorder(new LineBorder(ColorConstants.black, 1));
setBackgroundColor(classColor);
setOpaque(true);
add(name);
add(attributeFigure);
add(methodFigure);
public CompartmentFigure getAttributesCompartment() {
return attributeFigure;
public CompartmentFigure getMethodsCompartment() {
return methodFigure;
class TheDiagram {
public Shell shell;
public Figure contents;
LightweightSystem lws;
public void initialize() {
shell = new Shell(Display.getDefault());
lws = new LightweightSystem(shell);
contents = new Figure();
XYLayout contentsLayout = new XYLayout();
contents.setLayoutManager(contentsLayout);
lws.setContents(contents);
Font classFont = new Font(null, "Arial", 12, SWT.BOLD);
Label classLabel1 = new Label("Table");
classLabel1.setFont(classFont);
Label classLabel2 = new Label("Column");
classLabel2.setFont(classFont);
final UMLClassFigure classFigure = new UMLClassFigure(classLabel1);
final UMLClassFigure classFigure2 = new UMLClassFigure(classLabel2);
Label attribute1 = new Label("columns: Column[]");
Label attribute2 = new Label("rows: Row[]");
Label attribute3 = new Label("columnID: int");
Label attribute4 = new Label("items: List");
classFigure.getAttributesCompartment().add(attribute1);
classFigure.getAttributesCompartment().add(attribute2);
classFigure2.getAttributesCompartment().add(attribute3);
classFigure2.getAttributesCompartment().add(attribute4);
Label method1 = new Label("getColumns(): Column[]");
Label method2 = new Label("getRows(): Row[]");
Label method3 = new Label("getColumnID(): int");
Label method4 = new Label("getItems(): List");
classFigure.getMethodsCompartment().add(method1);
classFigure.getMethodsCompartment().add(method2);
classFigure2.getMethodsCompartment().add(method3);
classFigure2.getMethodsCompartment().add(method4);
contentsLayout
.setConstraint(classFigure, new Rectangle(10, 10, -1, -1));
contentsLayout.setConstraint(classFigure2, new Rectangle(200, 200, -1,
-1));
PolylineConnection c = new PolylineConnection();
ChopboxAnchor sourceAnchor = new ChopboxAnchor(classFigure);
ChopboxAnchor targetAnchor = new ChopboxAnchor(classFigure2);
c.setSourceAnchor(sourceAnchor);
c.setTargetAnchor(targetAnchor);
PolygonDecoration decoration = new PolygonDecoration();
PointList decorationPointList = new PointList();
decorationPointList.addPoint(0, 0);
decorationPointList.addPoint(-2, 2);
decorationPointList.addPoint(-4, 0);
decorationPointList.addPoint(-2, -2);
decoration.setTemplate(decorationPointList);
c.setSourceDecoration(decoration);
ConnectionEndpointLocator targetEndpointLocator = new
ConnectionEndpointLocator(
c, true);
targetEndpointLocator.setVDistance(15);
Label targetMultiplicityLabel = new Label("1..*");
c.add(targetMultiplicityLabel, targetEndpointLocator);
ConnectionEndpointLocator sourceEndpointLocator = new
c, false);
sourceEndpointLocator.setVDistance(15);
Label sourceMultiplicityLabel = new Label("1");
c.add(sourceMultiplicityLabel, sourceEndpointLocator);
ConnectionEndpointLocator relationshipLocator = new
c, true);
relationshipLocator.setUDistance(10);
relationshipLocator.setVDistance(-20);
Label relationshipLabel = new Label("contains");
c.add(relationshipLabel, relationshipLocator);
contents.add(classFigure);
contents.add(classFigure2);
contents.add(c);
Re: Problem saving Draw2d diagram to image from within plugin (works standalone) [message #244314 is a reply to message #244297] |
Tue, 15 July 2008 08:50   |
Originally posted by: lifesting.gmail.com
any exception message? did you debug this code to check all variable
contained correct info as you expected?
> shell.open();
> display.sleep();
> display.dispose();
> 102, 600, 600));
> img1.dispose();
> gc1.dispose();
> Shell shell =
> org.eclipse.swt.graphics.Rectangle(10, 102, 600, 600));
> img1.dispose();
> gc1.dispose();
Current Time: Sat Jul 19 19:45:49 EDT 2025
Powered by FUDForum. Page generated in 0.04109 seconds
