Dynamic Sorting base on a Report Parameter (e.g. using an Cumputed Column) [message #243326] |
Tue, 19 June 2007 11:29  |
Originally posted by: gerritpetersen.gmail.com
I have a problem. Depending of a Report Parameter, I want to sort the
dataset. The Report Parameter can have 6 value. Each value points to a
dataset field.
E.g. within the dataset 6 fields are read. field1 ... field6.
The report parameter defines which field is used to order.
So I thought to create a Computed Column (Named: Sorting) and include in the
query: "order by FIELDA, FIELDB, Sorting".
This (of course) gives an error. Is their a way to sort on a Computed Column
(or an other way of dynamical change the sorting).On such a way that also
the Preview Result of the dataset also shows the 'new' ordered data. (since
the query is rather complex and used in a Joint-Data Set.
THANKS IN ADVANCED!
Re: Dynamic Sorting base on a Report Parameter (e.g. using an Cumputed Column) [message #243783 is a reply to message #243640] |
Thu, 21 June 2007 02:35  |
You can sort in the table that displays the data set and simply use an
indirection for the sorting key: sort on
row[params["sortingColumn"]]
With a string param with combo box selection you should be able to have a
static list of choices that have a proper display text and map to the
correct column name.
Olaf
> Take a look at this example:
> http://wiki.eclipse.org/Example_-_Sort_Table_based_on_parame ter_%28BIRT%29
> Jason
> GP wrote:
>> Hi,
>> dataset field.
the
Column
>> THANKS IN ADVANCED!
FUDForum. Page generated in 0.03591 seconds
