Home » Archived » Maven Integration (M2E) » Add Dependecy?
Add Dependecy? [message #24181] Fri, 27 March 2009 09:23 Go to next message
Originally posted by: asddd.asd.com
When I choose my parent folder and select "Add Dependency" nothing pops up
when I eg. type "eas" in the search field. Normally I get about 174 hits
from another machine with Maven installed. Do I need to set something up in
the pom.xml file to access the repositories?
Re: Add Dependecy? [message #24221 is a reply to message #24181] Fri, 27 March 2009 10:21 Go to previous messageGo to next message
I have tried adding this to the pom.xml file:
<repositories>
<repository>
<id>maven2-repository.dev.java.net</id>
<name>Java.net Repository for Maven</name>
<url>http://download.java.net/maven/2/</url>
</repository>
</repositories>
But I still cannot add dependencies from the right click menu. I am also
sure that my other machine does not have the above XML snippet in its
pom.xml file.
"mlt" <asddd@asd.com> wrote in message
news:gqik1p$72a$1@build.eclipse.org...
> in the pom.xml file to access the repositories?
Re: Add Dependecy? [message #24262 is a reply to message #24221] Fri, 27 March 2009 13:31 Go to previous messageGo to next message
Just needed to install the repository plugin from the eclipse installer.
news:gqinel$2q3$1@build.eclipse.org...
> <repositories>
> <repository>
> </repository>
> </repositories>
> pom.xml file.
>> up when I eg. type "eas" in the search field. Normally I get about 174
>> hits from another machine with Maven installed. Do I need to set
>> something up in the pom.xml file to access the repositories?
Re: Add Dependecy? [message #24305 is a reply to message #24262] Fri, 27 March 2009 13:36 Go to previous message
Originally posted by: igor.ifedorenko.com
Yeah, you probably want to add yourself to
https://issues.sonatype.org/browse/MNGECLIPSE-725 ...
Igor
>> <repositories>
>> <repository>
>> </repository>
>> </repositories>
>> also sure that my other machine does not have the above XML snippet in
>> its pom.xml file.
>>> pops up when I eg. type "eas" in the search field. Normally I get
>>> about 174 hits from another machine with Maven installed. Do I need
>>> to set something up in the pom.xml file to access the repositories?
Previous Topic:M2Eclipse & Multiple JVMs
Next Topic:How to import a module project?
Current Time: Sat Jul 19 14:39:43 EDT 2025
Powered by FUDForum. Page generated in 0.26875 seconds
