Home » Newcomers » Newcomers » Code snippits
Code snippits [message #242563] Sat, 08 December 2007 09:43 Go to next message
Originally posted by: news_post.jimmo.com
Is there anyway other than the Aptana plugin to create snippets?
Jim Mohr
Re: Code snippits [message #242573 is a reply to message #242563] Sat, 08 December 2007 12:14 Go to previous messageGo to next message
James Mohr wrote:
> Hello,
> Regards,
> Jim Mohr
Hi Javes.
Yes, at least two different methods. First, check out the Scrapbook
(Help / Java Dev User Guide / Tasks / Using the scrapbook). This lets
you run code interactively and save scrapbook pages.
Second, there is a Snippets View. I haven't used this much, but it
appears to be designed for saving and pasting in frequently used code
snippets or possibly templates. I couldn't find any help topic on it. It
appears that, once you open the Snippets view, you can right-click and
select Customize to start creating snippets.
Does anyone know where the Snippets view is documented? HTH. Mark
Re: Code snippits [message #242584 is a reply to message #242573] Sat, 08 December 2007 17:52 Go to previous messageGo to next message
Snippets View comes from the Web Tools project.
Dave
Re: Code snippits [message #242589 is a reply to message #242584] Sat, 08 December 2007 19:43 Go to previous messageGo to next message
> Dave
Thanks, David. It would appear, from a quick check, that in the Eclipse
IDE for Java Developers, you get the Snippets view but not the Help
content (which appears to be in the Web Application Development User
Guide). It would seem that the same can be said for the XML Editor (and
perhaps other features as well).
Do you think this is an oversight/bug or just the way this is supposed
to work? I would think, in an ideal world, that if you get the feature
you would also get the help content. So I guess I am asking if I should
check bugzilla and create a bug if none exists? Thanks. Mark
Re: Code snippits [message #242594 is a reply to message #242584] Sat, 08 December 2007 19:45 Go to previous messageGo to next message
> Dave
Re: Code snippits [message #242599 is a reply to message #242594] Sat, 08 December 2007 20:01 Go to previous messageGo to next message
I would think this was a packaging bug, so one would need to open a bug
against the Eclipse Packaging Project, as I think that is where the
packaging is done for the various builds.
Re: Code snippits [message #242604 is a reply to message #242599] Sat, 08 December 2007 20:04 Go to previous message
>> should check bugzilla and create a bug if none exists? Thanks. Mark
I'll do it. Thanks. Mark
Previous Topic:Uppercase vs Capitalized environment var names during debug
Next Topic:Mylyn (and Eclipse) update problem
Current Time: Sat Jul 19 16:15:19 EDT 2025
Powered by FUDForum. Page generated in 0.10183 seconds
