Home » Eclipse Projects » GEF » Make Label in LogicEditor example resizble
Make Label in LogicEditor example resizble [message #23953] Fri, 04 October 2002 20:31 Go to next message
Could someone please tell me how to make Label in the logic editor example
resizable? I compare the edit policy of Label (non-resizable) with
ContainerEditPolicy (used by Circuit, which is resizable), I can't tell what
make Circuit resizable.
Thank you for any help.
Re: Make Label in LogicEditor example resizble [message #24027 is a reply to message #23953] Sat, 05 October 2002 01:06 Go to previous messageGo to next message
The LogicContainerEditPart (which the main LogicDiagram is) has a
LogicXYLayoutEditPolicy as its LAYOUT_ROLE. When a child is created in a
container, createChildEditPolicy(...) returns the appropriate EditPolicy
(resizable or nonresizable) to be installed as the PRIMARY_DRAG_ROLE on the
child EditPart. These are the edit policies that create the move and/or resize
commands.
LogicXYLayoutEditPolicy.createChildEditPolicy looks like this...
protected EditPolicy createChildEditPolicy(EditPart child){
if (child instanceof LEDEditPart ||
child instanceof OutputEditPart ||
child instanceof LogicLabelEditPart) {
return new org.eclipse.gef.editpolicies.NonResizableEditPolicy();
return new org.eclipse.gef.editpolicies.ResizableEditPolicy();
So, when a LogicLabelEditPart gets created, it gets a NonResizableEditPolicy,
while a CircuitEditPart would get a ResizableEditPolicy.
Hope this helps.
Eric
Sam Cheung wrote:
Re: Make Label in LogicEditor example resizble [message #24194 is a reply to message #24027] Sat, 05 October 2002 17:09 Go to previous messageGo to next message
Originally posted by: sy_cheung.yahoo.com
Eric,
Thanks for your help. How can I make a NonResizableEditPolicy NOT
movable also? I don't see there is a method in NonResiableEditPolicy to
make it not-movable also.
Thank you.
> a container, createChildEditPolicy(...) returns the appropriate
> EditPolicy (resizable or nonresizable) to be installed as the
> PRIMARY_DRAG_ROLE on the child EditPart. These are the edit policies
> that create the move and/or resize commands.
> NonResizableEditPolicy, while a CircuitEditPart would get a
> Hope this helps.
> Eric
> Sam Cheung wrote:
>> Hi,
>> example
>> tell what
Re: Make Label in LogicEditor example resizble [message #24234 is a reply to message #24194] Sat, 05 October 2002 20:32 Go to previous message
Originally posted by: hudsonr.us.eye-bee-em.com
If you have something that is not draggable, you should probably try to make
it look like a TreeItem or ListItem. So you might show selection by
changing the background to dark blue
(ColorConstants.menuBackgroundSelected), and the font color to white
(ColorConstants.menuForegroundSelected). Maybe handles don't make sense.
Handles are not the only way to drag something. You will also need to
override EditPart.getDragTracker() to return the SelectEditPartTracker(),
which doesn't allow dragging.
"Sam" <sy_cheung@yahoo.com> wrote in message
news:annj3m$ouh$1@rogue.oti.com...
> Eric,
> Thank you.
> > return new
> > Hope this helps.
> > Eric
> > Sam Cheung wrote:
> >> Hi,
> >> example
> >> tell what
Previous Topic:Make part of Label editable?
Next Topic:How to add edit part to a PolyLineConnection
Current Time: Sat Jul 19 08:27:02 EDT 2025
Powered by FUDForum. Page generated in 0.04247 seconds
