Home » Eclipse Projects » GEF » Palette View Refresh without open and close
Palette View Refresh without open and close [message #241313] Wed, 06 February 2008 11:21 Go to next message
Originally posted by: ranjeev.backbase.com
Hello there,
Context:
I am using GEF Palette to dispaly the PaletteContainer and Palette
Items. And the canvas is actually not from GEF. I have my own model
which holds the data on how the Palette tree structure will be built.
I have a created an Eclipse View which contains my own Viewer (say
DesignerPaletteViewer) which extends
org.eclipse.gef.ui.palette.PaletteViewer
My model is returned by this code Object[] contributions =
PaletteCoreManager.getInstance().getContributions();
the contributions array contains all my contribution.
my createBasicPaletteControls() creates SelectionToolEntry (which get
loaded always)
I have the following method in DesignerPaletteViewer:
public void displayPalette() throws PaletteCoreException {
createBasicPaletteControls();
addPaletteContributions(contributions);
setPaletteRoot(paletteRoot);
this.setActiveTool(selectionTool);
My problem is when I run this code, it does not refresh the Viewer until
I close and open the Palette View in Eclipse manually. I may have some
WorkspaceJob running in the backgroud to load the model, once it is
loaded I want that the notifier updates the DesignerPaletteViewer
dynamically., which inturn displays my complete Palette Tree structure.
Is there a way to refresh the PaletteViewer?
I am using GEF 3.3.1
Thanks in Advance
Ranjeev
Re: Palette View Refresh without open and close [message #241322 is a reply to message #241313] Wed, 06 February 2008 13:28 Go to previous message
Ranjeev 写道:
> Hello there,
> Context:
> loaded always)
This tell us the viewer work fine. but not updated
Not known your refresh efect, so guess check GEF PaletteView, which has
a perspective listener registered.
> Thanks in Advance
> Ranjeev
Xiangya
Previous Topic:Workbench state is not being saved for GEF editor
Next Topic:Exception in gef shapes example:java.lang.NoClassDefFoundError: Could not initialize class org.eclip
Current Time: Sat Jul 19 17:10:11 EDT 2025
Powered by FUDForum. Page generated in 0.04916 seconds
