Home » Archived » BIRT » Chart with dynamic SQL
Chart with dynamic SQL [message #241040] Mon, 04 June 2007 11:42 Go to next message
Originally posted by: xxx.xxx.com
I was trying to create a chart using a dataset created by a dynamic SQL
(with parameter markers inserted in the query).Then I have created
dataset parameters and linked them with the report parameters.But in the
chart wizard, when I selected the dataset no columns were shown to
select x and y axis from.
When I changed the dataset not to include the parameter markers, I could
see the columns for the dataset in the chart design wizard.
Is it a bug?
Designer used - Birt 2.1.2.
Re: Chart with dynamic SQL [message #241045 is a reply to message #241040] Mon, 04 June 2007 11:55 Go to previous messageGo to next message
Probably a bug. Does it happen with 2.1.3 too?
David
"Kris" <xxx@xxx.com> wrote in message news:f41btu$n5i$1@build.eclipse.org...
> Hello,
> (with parameter markers inserted in the query).Then I have created dataset
> parameters and linked them with the report parameters.But in the chart
> wizard, when I selected the dataset no columns were shown to select x and
> y axis from.
> Is it a bug?
> Thanks
Re: Chart with dynamic SQL [message #241050 is a reply to message #241045] Mon, 04 June 2007 12:08 Go to previous message
I havent tried with 2.1.3.
> David
>> Hello,
>> y axis from.
>> Is it a bug?
>> Thanks
Previous Topic:Cannot Preview the Report: SWT ERROR
Next Topic:How to organize reports in BIRT RCP w/o Projects or Folders?
Current Time: Sat Jul 19 21:47:51 EDT 2025
Powered by FUDForum. Page generated in 0.04111 seconds
