Home » Modeling » GMF (Graphical Modeling Framework) » Compartments to fit children
Compartments to fit children [message #237323] Thu, 23 July 2009 08:36 Go to next message
Does anybody now the solution to the following problem:
I have a parent component which stores it's children in a compartment -
how can i make the parent component fit its children (it needs to resize
when accepting new children)??
The whole thing works if i create the parent component with one click, but
if i outline the parent component while creating it then the parent
component keeps the given dimensions and creates a scroll bar within if
the child size is greater then parent size.
I'll take any ideas, i'm banging my head with this one...
Thank you
Re: Compartments to fit children [message #237336 is a reply to message #237323] Thu, 23 July 2009 09:22 Go to previous messageGo to next message
You could try to set 'preferred size' in your figure descriptor for your
node!
I did a quick test and it seams to work ok!
let me know how you get on,
hope this helps,
Gary
Re: Compartments to fit children [message #237403 is a reply to message #237336] Fri, 24 July 2009 05:33 Go to previous messageGo to next message
Thank you,
I've all ready done that, but unfortunately it isn't working.
Here is a video that more accurately describes the situation:
http://www.fesb.hr/~jomaras/videos/component/comp.html
or just the video at: http://www.fesb.hr/~jomaras/videos/component/comp.mp4
Thank you
Re: Compartments to fit children [message #237445 is a reply to message #237403] Fri, 24 July 2009 16:43 Go to previous messageGo to next message
You could try override the getMinimumSize() to return the preferred size.
Something like:
public Dimension getMinimumSize(int hint, int hint2) {
return super.getPreferredSize(hint, hint2);
From you video I see that you are explicitly setting the size. If you
select "Auto Size" from the toolbar, your figure would expand out. The
width and height constraints need to remain -1, -1 for the preferred size to
accomodate all the children.
- James.
"Josip Maras" <jomaras@gmail.com> wrote in message
news:58cddf5ae94d4a7fc9b26902b2ee0be5$1@www.eclipse.org...
> Thank you,
> I've all ready done that, but unfortunately it isn't working. Here is a
> Thank you
Re: Compartments to fit children [message #237451 is a reply to message #237445] Fri, 24 July 2009 16:44 Go to previous messageGo to next message
... or
return getPreferredSize();
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:h4d66p$nio$1@build.eclipse.org...
> Something like:
> @Override
> to accomodate all the children.
> Regards,
> - James.
>> Thank you,
>> Thank you
Re: Compartments to fit children [message #237511 is a reply to message #237451] Mon, 27 July 2009 03:27 Go to previous message
Hi James, THANK YOU!!
I've overridden the getMinimumSize() method in the parent figure
descriptor - and now everything works - thank you.
In the last couple of days i've tried a lot of, now i see, complicated
things - but this works just fine..
Previous Topic:Multiple (or more than one) compartments on canvas
Next Topic:Cascade deletion in EMF/GMF
Current Time: Sat Jul 19 22:47:56 EDT 2025
Powered by FUDForum. Page generated in 0.04366 seconds
